Kenwood kdc-138 raido... new was hooked up for 1 1/2 hr. started to flash a code "OCER" i now get now power to anything.. lights on deck still work.
  • 1,512 Answers
Hi hornet8602
Check out this tip...
That should sort it out for you mate... :)
regards
Graeme
Posted on Apr 28, 2008
My kenwood kdc 136 works normal for ten minutes then stops and displays ;ocer
I had an issue like this took me months to fix it. I finally just put in a higher grade fuse in. I think it had a 10 and i put in a 15 worked after that but mine was not wired to the battery. I would say check your fuses and wires.
Apr 20, 2014 | Kenwood KDC-138 FM / AM Receiver
What does error code OCER mean on a kenwood model KDC-135
I'm not sure what it means, but try hitting the little tiny reset button on the front of the deck to fix it.
Jul 11, 2010 | Kenwood KDC-135 CD Player
Turn it on in it says ocer
Here's the Manual for your KDC-138 deck...
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
On Page 18 it describes the error that you're seeing... let me re-type it here:
PROTECT / DCER: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
-- Wire or insulate the speaker cable properly and press the reset button
I found on Page 3, the reset button is located just below and to the left of the volume knob...
I hope that helps.
Mar 24, 2010 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138: Removed Old stereo, installed new KDC-138, I'm getting power to the plug that plugs into the back of the unit & fuse is good. I've tried pushing the reset button. Nothing comes up on...
do you have power at both supplys on the wire harness?( red and yellow) red wire will have power with the key on. Also make sure your ground is hooked up right.
Aug 02, 2009 | Kenwood KDC-138 FM / AM Receiver
I turn on the radio and OCER is shown in the faceplate and it doesn't do anything else.
Hello miguel200819,
The "PROTECT/DCER" error is caused whenever a speaker wire is shorted or grounded by contact with the vehicle frame. Locate and repair the shorted/grounded wire or run a new one and then "reset" the receiver by pressing the reset button to the lower left of the volume control. If this does not work, the receiver is faulty and needs to be serviced.
Hope this helps.
May 20, 2009 | Kenwood KDC-138 FM / AM Receiver
:OCER
Ive had this problem lots of times I cant find the underlying cause but for a quick fix just hit the little reset button on the bottom left corner. Im still trying to find a way to stop it from constantly happening
Sep 05, 2008 | Kenwood KDC-138 FM / AM Receiver
64 people viewed this question
 Grubhead
Grubhead
