There is a small T-10 or T-15 Torx head screw that is recessed in the clutch drum end screwed into the end of the crankshaft. If you loosen it, the drum should come off but the screw may still remain inside the end of the drum. This is normal. Clutch itself unscrews from threads on the crankshaft in counter-clockwise rotation. Use a blunt flat-blade chisel or the like and place on the inner ears of the clutch near the middle and strike with hammer...not real hard...just hard enough to shock it loose...maybe apply some penetrating oil to the center of it beforehand.
