Question about Dishwashers
When turned on, the dishwasher will trip the safety switch
  • 26 Answers
Sounds like a short circuit....could be almost anywhere....for safetys sake get it checked by a competent electrician/repairman
Posted on Apr 28, 2008
Is it worth trying to repair a conia dishwasher that tripped our safety switch and appears to have burnt out the element?
May be an element that needs to be replaced. It also may have taken a logic board along with it. What make and model number are you asking about?
Aug 19, 2015 | Dishwashers
Kudi02cr Kitchen aid dishwasher not turning on. No lights nothing
check your breaker panel to see if the dishwasher breaker might be tripped. then be certain that the door is closing all the way and engaging the safety switch
Jul 04, 2014 | Dishwashers
Dishwasher won't turn on trips safety switch
This dishwasher has a serious electrical fault that caused the safety switch to trip.
You need this to be repaired by a qualified repairer.
Apr 12, 2013 | Miele 23 in. Novotronic G841 Built-In...
When we switch the dishwasher on it trips the electricity. It's worked fine for 2 years but now won't work at all and just trips the electricity.
Your dishwasher has a serious electrical safety fault which is causing the protective breaker to trip (although it may have a simple and cheap cause). With all due respect, your question clearly demonstrates that you lack the knowledge and skills to carry out a diagnosis and a safe repair (especially vital for anything which uses water and electricity). Before doing anything else, fully disconnect your machine from the main electricity supply by either unplugging it or for a machine connected to a flex outlet by turning off the wall switch and then removing the fuse.
Sorry, but in this instance you only have two choices: get a qualified dishwasher repair engineer in or replace the machine. Anything else could be lethal.
Oct 08, 2010 | Beko Dishwashers
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Main power safety tripping when i turn on dishwasher power - Help
in the long run i would go with a new one...use less power get parts longer looks better wife will be happy hi hi
Aug 17, 2009 | Dishwashers
Hi had trouble with water tap feeding dishwasher , was leaking
it trips the safety switch because the machine is unsafe
call an electrician to do an insulation check , wiring and component check
Nov 18, 2017 | Siemens 24 in. SE25A091 Hi-Line...
Asko dishwasher trips safety switch when turned on
dont know what model you have but check to see if theres a broken wire in the door right side bottom,check the element or the wax motor red right side top in door if your model has a drying fan.if this doesnt help i will need to know your model no
Apr 09, 2008 | Dishwashers
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
