Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Unclear Display I didn't have a problem with this monitor when I was using it with Dell computer.  Sometime ago, I don't know what caused it but my Dell just died.  I've been getting error messages regarding the system fan and it suddenly died.  I just purchased a macmini and connected it to my samsung syncmaster 204b thinking that i would work fine.  Somehow, all the images are not coming out clearly.  When I open up a new document file with a white background, I see flickering red sheen over it.  Help!
    Scholar:
  • 130 Answers
Goto cotrol panel/display/settings and set the resolution to 640x480. Make your you are using the video driver from the manufactorer for your video card. Windows generic drivers do not work well for all monitors. When you get the proper video driver you can reset your resolution back to a higher setting.
Posted on Jun 20, 2008
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
After updating graphics drivers, I don't know how to adjust scaling on my sell ST2321L monitor so the 1 inch black frame around the display is gone
Go to display setting on the monitor and adjust Horizontal and Vertical Positions
Use the icon-down.gifand icon-up-1.gif buttons to adjust image up / left and down / right. Minimum is '0' (-). Maximum is '100' (+).
Aug 30, 2012 | Dell ST2321L Black 23" 5ms LED Backlight...
I turn on my computer and i don't see anything
Guess what? I don't see it either.
Oh,....that's because you're there, and I'm here, and.............never mind.
(OH, I'm jus jokin'!)
Would be helpful to know the laptop manufacturer name, and model number, though. The name you know, the model number is on the bottom of the laptop.
Diagnose to see what the problem is;
A) Graphics chipset,
Or
B) Video Cable,
Or
C) In the Display Assembly
1) Suggest start with attaching a VGA monitor to the laptop.
Laptop OFF, monitor OFF, attach the VGA cable of a VGA monitor, to the VGA connector on the laptop.
Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available,
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Hold the Fn key down, and tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Don't know. You didn't state the laptop manufacturer name, and model number.
It is one of the F keys at the top. F1 through F12.
Usually has a monitor symbol on it, and a side arrow.
(Most of the time the F4, F5, F7, or F8 key)
No display on the external VGA monitor?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Still no? Bad graphics chipset.
Display shows on external VGA monitor? Problem is the Video Cable, or in the Display Assembly.
Post back in a Comment after you have performed this procedure, and also post the manufacturer name, and model number.
If the graphics chipset is good, we'll go on with the diagnoses if you wish.
Regards,
joecoolvette
Jul 14, 2012 | Computers & Internet
My Settings/Advanced/Displays, don't show, there is no setting to use any ex. screens I have 2-Inspiron 8500s my other one shows the setting display but one don't can you tell me what to do to get...
LAPTOP OR NOTEBOOK COMPUTERS HAVE A KEY ON THE KEYBOARD IN THE LOWER LEFT SIDE THAT HAS A "Fn" MARKED ON IT, SHOULD BE BY THE CTRL KEY. PRESS THIS KEY ALONG WITH AN "F"KEY, NORMALY F5, ( HAS 2-BOXES WITH A DIVIDER LINE), WILL CAUSE YOUR SCREEN TO GO BLANK AS IT IS NOW SENDING THE VIDEO TO AN EXTERNAL MONITOR. PRESSING THE 2-KEYS AGAIN WILL APPLYTHE VIDEO TO BOTH MONITORS, THEN PRESSING BOTH AGAIN WILL RETURN IT TO YOUR LATOP ONLY.
Aug 24, 2011 | Dell Inspiron 8500 Notebook
When I connect power to my Dell E198FP monitor, the power button flashes green and there is a small chirping noise and it won't display anything. It will also not allow me to power on/off the monitor but...
This is a failure of the power supply in the monitor. It can be easily fixed by replacing a pair of failed 680 microfarad 16 volt capacitors. If you have a friend who is handy with a soldering iron they will be readily apparent as failed since the top will "bulge". I just put this monitor back together and didn't write down the designators, unfortunately. This is the second monitor I have repaired with this failure...apparently the value is not terribly critical, just don't use caps with a lower voltage rating. I actually just replaced them with a pair of 100 microfarad 50 volt caps since it was what I happened to have on hand and the monitor worked fine once repairs were complete.
Nov 16, 2010 | Dell E198FP LCD Monitor
When i switch on my computer my monitor displays monitor going to sleep
First of all, please try it on another computer. And let me know the result. This will lessen the troubleshooting task. We'll be able to assume which one, whether the monitor or the Display card is the cause. Good luck. Thanks for using FixYa.
Jun 04, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Just got a new computer DELL Studio...hooked it to my existing monitor (big W3000 / DELL)when i leave the office & it times out....i come back in & i move the mouse but the computer does'nt cpme...
Tom, try connecting a KNOWN GOOD monitor to your PC. If it works fine for 2 hrs and will recover from "time-out" then I would think that the monitor is having a problem with it's backlighting system. Have you had any problem with black screen while doing constant keyboard and mouse movement? Try adjusting time-out settings under "Control Panel" then "Display" then "Power" and select not to turn off monitor. See if that fixes the problem. 12fixlouie
Dec 15, 2009 | Dell Computers & Internet
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell monitor problem
hey buddy, its seems to be the display driver problemi think..
please install the correct display driver for your VGA card in the CPU.. let me know?
Dec 13, 2007 | Dell E173FP 17" LCD Monitor
Monitor blackout thought green powerlights on
When your dell e173fp lcd monitor black out, the led power light are still green color. Normally, this will be the inverter board or ccfl lamp problem. May i know, after this monitor black out, do you have try use the torch light to see any display on the screen? (sometime the display are darkness only and not totally no display, you need see it clearly). Any details on repair lcd monitor please goto this website, http://www.fastrepairguide.com
Sep 01, 2007 | Dell E173FP 17" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
145 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
