Question about GE Advantium 120 Convection/Microwave Oven
No display, no power, complete blackout
I took off the front grill and found one fuse. I tested the fuse with my home volt meter. The volt meter works when I touch the red and black ends together, but when I touch the red and black ends to the ends of the fuse, I get no signal. Does that mean it is bad or is my test incorrect? Thanks for your help
  • GE Master
  • 9,098 Answers
Yes, the fuse is bad. Be sure to use a ceramic fuse of the same current (Amps) rating.
They're available at appliance parts stores, hardware stores, Lowe's, Wal-Mart, etc.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 28, 2008
I can see the fuse , how do I get the front panel off my microwave.
Since you have the top grill off you are almost there. Make sure the plug is out or breaker off. There should be 1 screw at the top center of the control panel. Remove screw and lift up on the control panel. It should lift and then tilt towards you so you can access the fuse.
Mar 01, 2015 | Frigidaire PLMV169DC Microwave Oven
MICROWAVE FUSE BREAKDOWN
follow this test and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 26, 2013 | Microwave Ovens
Oven not working but grill is
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Oct 27, 2013 | Daewoo Microwave Ovens
Replace microwave coil
If your microwave is totally dead, it may be the line-fuse that is the problem. Leave the microwave unplugged for a day (it may contain a capacitor that could have residual electricity that could give you a nasty jolt). Undo the screws that hold the front outgoing-vent grill.
You may be able to see the fuse through the secondary grill (they don't want you touching the circuit-board, but you may have to). The line-fuse may be attached to the circuit-board.
If it is, undo the secondary grill screws, and bend the tabs that hold the secondary grill to remove the secondary grill.
Pull-out the fuse from the fuse-holder, and get an ohm-meter to test. If the ohm-meter reads near-infinite ohms across the fuse, get a magnifier to read what is on the end of the fuse.
The imprint on the old fuse should mention a rated voltage, and amperage.
Then go to Radio Shack, and buy an equivalent replacement fuse.
Replace the line-fuse with a new one, plug the microwave back in, and see if the display comes-alive, and if it does, set the clock ad try to heat a cup of water. If the cup of water heats, replace the secondary-grill (careful, that capacitor is now in-play) and screws, replace the outlet-vent-grill and screws -- you may not even have to take the microwave off of the wall !
Sep 27, 2013 | Samsung Microwave Ovens
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
No power. I changed fuse but microwave blows it immediately.
Be very careful! Standard microwaves have 2100volt capacitors and commercial ones 4000 volt capacitors.
*Decharge your capacitor(s) before doing diagnostics*.
You are now testing the high voltage side (as it works on convection). The main components are a transformer, a capacitor, a diode and a magnetron (havent seen a triac in a panasonic residential). If you have a proper meter that can test uf, decharge the capacitor, then test the capacitor, if it reads 0, you need a new capacitor (10$ used typically, 14$ new from ebay). To test the magnetron, decharge the capacitor first, remove the spade connections, test each leg to the frame of the microwave... if it shows measurable resistance, the magnetron is bad. The transformer is not something you test as I personally dont have a 4000 volt meter. If the diode, the magnetron and capacitor are okay, then the transformer is bad. To eliminate any other function, disconnect the low voltage to the transformer run a micropower cycle and check the fuse.
Hope that helps. My first instinct is the capacitor.
Nov 14, 2009 | Panasonic NN-T888S Convection/Microwave...
No power ,completely dead
the fuse may be bad.if u r somewhat handy. you can try and fix yourself . fuse can usually be purchased at a home improvement store. 20 or 15 amp fuse. un plug unit remove top grill usuallly two phillips scews in the grill or 2-3 screws on the top of the microwave frt. next remove front control panel usuallt 1 screw at top of panel . once the control panel has been removed you can look inside that area and see a fuse, its ceramic usually white or grey and sits in a fuse holder. you can test it if u have a meter. should read resistance if good if no reading it is bad. replace it with same volt youtook out. if you rather a servicer doing it, then could cost anywhere from 65.00 to 105.00 to fix in home. if u take it in to get repaired then 85.00-125.00 depending on were u live and who u use. do it yourself for around 2.00-5.00 for fuse.always check power to unit first before you repair . use a extension cord to same outlet and see if that appliance works.hope this helps you.
Oct 06, 2009 | Microwave Ovens
Cookworks microwave not working
replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
Jul 29, 2009 | Microwave Ovens
Microwave is not getting power
may i please ask you if you have a meter? check that 120 volts is going in? check the buttons that you press. also check the fuse check the mains cable for any breaks. also you may want to test the display to see if any power going in?
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
135 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
