Question about Lands Phones
I turned the answering machine off several days ago. Now it will not come on. The clock, announcement, etc. also will not work. The model is IA 5882. S/N ES300706091. The unit was purchased in 12/07 for Christmas. I bought my daughter a set also and hers is working fine. Pls advise
  • 5 more comments
  • ronald1936 Apr 28, 2008
    The caller ID works and the phone part works. I checked to ensure that the unit is plugged in properly. What next?
    I have the user manual, but it does not tell how to rerset. What page can I find this info.
    I( tried everything in the user manual. P31 & p39-48. I tried accessing the system from a touch tone phone, per page 36. Still no go.
    This is a cordlesshone. it does not have a fax capability.
    The handset battery is fully charged. I can make a call and receive a call. The caller ID is working fine. The problem has to be in the answering machine area.
    None of the suggestions offered by you and you coworkers have solved the problem. It appears to me that you do not have a solution. Thanks for the effort. Ron
    This solution has been tried. It is found on page 48. Thanks for the effort. I'll just buy a new phone. Ron
    Master:
  • 377 Answers
Please check for the power cord is plug into the outlet or make check that the fax have power coming from it.
Thanks
Posted on Apr 28, 2008
    Genius:
  • 1,665 Answers
Did you try a reset?
  • 4 more comments
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 28, 2008
    Have a look at page 31
    Better at page 39 (troubleshooting)
    Also make sure its battery is fully charged
    Charge the handset battery
    The battery may have enough power to allow for short calls.If the battery power is low, NEEDS RECHARGING will appear on the handset screen.For best performance charge the battery for at least 16 hours the first time.
    • If the unit is not responding normally, try putting the cordless handset in the telephone base or the charger.If it does not seem to respond, try the following (in the order listed):
    1. Disconnect the power to the telephone base.
    2. Disconnect the battery on the cordless handset and the spare battery in the telephone base.
    3. Wait a few minutes before connecting power to the telephone base.
    4. Re-install the battery and place the cordless handset into the telephone base or charger.
    5. Wait for the cordless handset to synchronize its connection with the telephone base.Allow up to one minute for this to take place.
    If above procedure has no result, perhaps your unit board, internal cables, keapad etc , must be inspected but some experience in electronic troubleshooting is necessary.
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
How do i set the clock
what model machine do you have? If it is similar to what I've had maybe i can walk you thru it.
Press change and CH should show in the display window. Press and release clock button and it should announce the day, to change the day setting hold down the skip/scan button or the repeat/scan button (this is for whether you want to go forward or back, i.e. from Friday to Thursday, etc. When you get correct day set, press and release clock, again & go thru holding down the skip/scan or repeat/scan buttons till you have correct hourly time, release button. Press clock again and repeat the skip/scan or repeat/scan until you get correct minutes, release button. To check if you did it correctly press and release the clock button. It should announce the correct day and time.
I hope this helps you, if your answering machine is similar to mine this should work. If it isn't give me the model number and I can try getting you a manual. Good luck, Barb
Feb 26, 2011 | AT&T Lands Phones
Need to set date and time on the base.
To set the clock, press and hold Clock until you see a C in the message window. The current (or default day) will be announced. Hold either Memo/Repeat or Annc/Skip until the correct day is announced. Then release the button. Press and release Clock.
The unit will announce the current hour setting. Hold either Memo/Repeat or Annc/Skip until the correct hour is announced. Then release the button and then press and release Clock.
The machine will announce the current minute setting. Then hold either Memo/Repeat or Annc/Skip until the correct hour is announced. Then release the button. Press and release Clock.
The current day and time will be announced. In the future if you press and release Clock, the day and time will be announced.
Additional setting information is on the bottom of the unit - for resetting after a power failure.
The manual for the AT&T 1717 is available here: http://www.retrevo.com/support/AT%26T-1717-manual/id/473bh041/t/2/ . You will need to solve a captcha to download the file.
I hope this helps.
Feb 01, 2011 | AT&T 1717 Digital Answering Machine
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
release the button.
3 Press and release Clock. The current
4 To change the hour setting, hold down memo/repeat
release the button.
5 Press and release Clock. The current
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
7 Press and release C. The new day
and time are announced.
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Need to change the date and time
message is received. Press "Play/Stop" to exit
1 Press and hold "Clock" until the
"Memo/Repeat" or "ANNC/SKIP" until the
release the button.
3 Press and release "Clock". The current
"Memo/Repeat"or "ANNC/SKIP" until the
release the button.
5 Press and release "CLOCK". The current
down "Memo/Repeat" or "ANNC/SKIP" until the
7 Press and release "CLOCK". The new day
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
"C" in display window and "power failure" keeps getting announced
Set the Clock
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
is announced.
release ror auntil
3 Press and release C. The current
release ror auntil
5 Press and release C. The current
release ror auntil
7 Press and release C. The current
year is announced.
release ror auntil
9 Press and release C. The new day,
Feb 26, 2008 | AT&T 1738 Digital Answering Machine
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
setting the clock.
is announced.
release ror auntil
release ror auntil
release ror auntil
year is announced.
release ror auntil
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
Time and date
Setting the Clock
message is received. Press P to exit
1 Press and hold C until the
or until the
release the button.
or until the
release the button.
down or until the
C.
Oct 04, 2007 | AT&T 1717 Digital Answering Machine
Lands Phones Logo
61 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
