Question about Lakewood 2727 Heater
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
My dog ate right through the black cord...directly to the wires, and frayed them. You can see the metal wires all exposed and frayed. (Luckily it was unplugged when this happened).
How do I replace that cord? I put electrical tape around it (the black colored elec tape), but I don't think that's a good idea (particularly since the wires are frayed and exposed).
SO... either I throw it away and buy another one. OR, where/how can I replace the cord. The cord is not easily removed from the unit itself. What do I do???
    Champion:
  • 254 Answers
Another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Posted on Jun 04, 2008
The remote cord is frayed the full length exposing wires within. It's the model designed for 350# capacity
wrong site fixya doesnt sell products need to direct your request to the proper company
Nov 05, 2017 | The Office Equipment & Supplies
I charged the truck with charger while still hooked up 2 car.. now no tail lights, turn sig, brake, or dash all out but everything else works fine, also dogs ate my tow connecter off rear and it's
Check your fuses in the fuse box (you may have a couple fuse boxes), this should be the first thing you do.
Scott
ASE Certified Automotive Technician
ASE Certified MED/HVY Truck Technician
Jan 23, 2013 | Cars & Trucks
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
Jul 22, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
I have an older model RCA television ( but it's ot all the hook ups for today) and my dog accidentally ate through the cord, should I take it to a shop or just buy a used tv somewhere else & not even...
I guess it depends how far up the cord your dog ate through it! You could cut the cord off at the bite, fit a new plug and use an extension cord to reach the socket. Other than that, I don't think its an expensive job to get a complete new cord fitted - depending on the repairer, it should still be cheaper than a replacement tv
Feb 04, 2011 | RCA Televison & Video
I need to replace the power cord on my Kenmore 70 series washer (the dog ate it) How do I get to that part of the washer?
google applinace repair, choose a company i like parts select or sears enter model number find part replace.easy fix/ always make sure your ground/ green wire is installed to metal on washer
Jan 17, 2010 | Washing Machines
My friend has a Tristar MG1 vacuum. The cord was
Chances are that there is the tiniest fray of one of the wires touching somewhere. Since you have already made a good repair with nuts and tape, feel the length of the cord for other bite marks where a puncture might short the cords. If you find such a site, **** the sheath lengthwise, tape the wires and replace them in the sheath, then tape the sheath closed.
Regards, --W/D--
Aug 10, 2009 | Tristar Vacuums
I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Mar 26, 2009 | Emerson EWF2704 TV
Mice ate wiring
Try to trace all wires and see if the metal part is still intact. Do not turn it on or allow electricity to pass yet! If wire metal intact, get some good quality black electrical tape and carefully tape all the exposed metal. When done, test system.
To prevent problem, use moth balls, fabric softener sheets, or pine sol soaked on cloths to deter mice & rats. If possible, use old- fashion mouse or rat traps with peanut butter to kill intruders to your boat. If you agressively eliminate them, the problem will be solved, but you may have to periodically repeat the trap use.
Dec 15, 2008 | Boating
Cord to plug in
On a 120 volt plug, the smaller plug is black, power. The larger side is white, neutral. The center round plug is green, ground. Make sure your ac is not 220, the plugs are in line above the neutral. On 220 both are power.
Aug 05, 2008 | Goldstar M1003R Air Conditioner
Dog chewed power cord
you have to take the machine completely apart and get inside where the motor is.take the cover off there are 3 screws 2 on the left side behind the hose and 1 on the right side back by the wheel.that will take the covr off.now where the upright sets on the base you will see a ******** each side of the motor, take those off,that will seperate the upright from the base.now you have to open the motor housing,there are 4 screws 2 on the front side and 2 on the bach side that will expose the motor and the cord.take out the old cord and splice in the new one.then put it all back together in reverse of how you took it apart.please leave feedback
Feb 27, 2008 | Dirt Devil Featherlite Bagless Vacuum...
Lakewood 2727 Heater Logo
216 people viewed this question
Top Lakewood Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Paul Carew
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
