Question about Motorola Mobility RAZR V3x Cellular Phone
Help me fix my Motorola v3x
I was gona take a picture of my friend when suddenly ano error occured.. saying it was Busy! after that, my LCD turned blue... and everytime I turn on and off my cellphone the same thing happens over and over... pls help me anyone....
  • Anonymous Apr 30, 2008
    can u help me?
    i was taking a photo with my sister and my camera error and turn into different colors and i close it that hoping it will work but after i do it my phone got worst i cannot open it and i always see a different colors
  • 26 Answers
My v3 used to act funny sometimes
i took back off and tweaked the little metal bits on the inside of the back cover and it has behaved itself ever since
remove battery while you're at it
hopefully it will work for you
Posted on Apr 28, 2008
How to fix my razr v3x camera?? i need help!!
go to settings then click on master reset,and should work like new witout problems.if my info was of any help please leave a comment ,thankyou.
Sep 02, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Razr v3x screen suddenly won't work even with phone turned on. Yesterday it was working just fine then this morning lcd is dead. I can hear it when somebody sends me an sms but I cannot read it since...
check the oem ribbon that runs to screen. the design of phone hinge is faulty, and usually cuts the ribbon that runs up to the screen after months of openings and closings,preventing it from lighting up. sometimes its the earpiece wires on the ribbon that get cut which prohibits u from hearing anything when u hold the phone to your ear and u have to switch to speaker...bummer..sooo my friend, CHECK THE RIBBON.
Mar 11, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Please help me!!!
The problem is caused by a loose cable connection or the connection from the main board of the phone to the camera not being connected correctly or not at all. The easiest fix is if you have a repair store near by you can drop it off and have it fixed or if you know your way around electronics you can just reconnect the flex cable to the board and viola it will work.
Jan 23, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Camera not work
when I open the camera .isee this massage( busy.try again later)
my phone is motorola v3x
Jan 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola RAZR V3X
hi, this isn't a solution but it might help explain the possible problem. The v3x camera has a connector in order to connect it to the rest of the phone parts. If that connector is loose or possibly has broke you will get error messages. The only way to know is to have a technician take the v3x apart and check. The V3X is not as easy as the v3 or v3xx to take apart and you must have the correct tools. If needed the camera unit can be replaced so that you don't have to purchase a new phone. If you can find a technician in your area you can ask if he has a v3x that he uses for parts. It would be less expensive. Good Luck.
Jan 12, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Problems with my motorola v3x
if the display on your screen is only half of it, it means that the theme installed in your fone is not for motorola v3x.
with regards to the backlight, the connector from the lcd to the board is loose.
if you can only see the white light, it means that your fone is running an application, loading or hanging up like what's happening in pc's.
i think you need to master reset your phone and put only a 256memory card. even though it is said to carry up more, just stick with the 256 memory to avoid those problems.
Oct 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
hi!! with regard to your problem stated it seem that you have a flex problem! if you know have to change the flex of your phone you can try purchasing on ebay. but the safest thing to do is bring your phone to a repair shop, better if you can bring it motorola service center where they can handle the repair with no problem!
MOTOROLA V3X PROBLEM
If it's new take it back under warranty. It's a software problem. If it isnt under warranty, then you could reflash the phone.
May 01, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3x screen fix
guys! my fone got blocked . when i turn it on it says SIM Blocked...what do i do? then it says PIN1 UNBLOCK code:?
Nov 08, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
