Question about LG WM0642H Front Load
LG WM0642H* I stupidly removed the two screws (thinking I'd reverse the front-loading door) at the point where the door latches to the housing. Something fell. A strike plate of some kind? Anyway, I cannot get to it now. How do I access the interior to retrieve the missing piece?
    Problem Solver:
  • 4 Answers
Remove the 4 dispenser area screws. Depress side dispenser tabs to drop dispenser assembly from the top lid .Insert an opener or flat item into top lid and front panel space to depress inward the metal lid top hold down clip.Do left side first then right.Raise the lid and look down behind lock mechanism.Or tilt washer and look underneath. It's an open area below?
Posted on Jun 17, 2010
HOW DO I REVERSE THE DOOR ON LG FRONT LOAD WASHER
sorry but it cannot be done, not built to do so
Aug 21, 2013 | LG WM0642H Front Load
How to replace lg rubber gasket forn a front loading washing machine model wm0642
You will need 2 special tools to remove and install the door gaskets. The springs are very hard to put back together with anything other than the proper LG tools.
Good luck
Jun 04, 2011 | LG WM0642H Front Load
A piece of clothing got sucked down the lint vent and now the dryer makes a loud squeeling noise. I need to know how to disassemble the dryer to get to the piece of clothing
LG dryer disasembly notes:
To disassemble remove the top first by removing screws in rear. To take off the control remove to screw on each side of the back. All connectors are color coded. Cannot screw up reassemble.Lift control out and up. Control board has 4 screws and is replaced as a unit. Keep the selector knob.
Removing and reversing the door
Remove the screws from opposite side and then remove the latch pull out the latch no wires are there. Take the door off and reverse it then replace the latch and shorter screws for extra holes.
Remove the front:
Disconnect the dryer light and door switch wires. Move harness out yer way. Remove 2 screws at the base of the door opening and 4 screws along the top. Tip the panel to the front and lifts off. Next remove the top bracket 2 screws each end. Lift brace up and off.
To remove the shroud/panel 4 screws are removed and lifted up and pulled forward. Disconnect the wire to the humidity sensor.
Remove the belt from idler and yank the drum out. (The belt goes under the tensioner then over the pulley then release it and the spring holds everythang in place like a DOT dryer.) The grooved/ribbed surface goes to the tub side.
LG Dryer
Jan 30, 2011 | LG DLEX3001P Dryer
Kenmore washer HE3 broken door latch. How do you replace
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Our washer has error code LE
It means: Latch Error. It doesn't detect the door latch as closed. Latch may need to be replaced.
May 04, 2010 | LG WM0642H Front Load
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
How do I reverse the dryer door on my front loader LG
No electronics involved in reversing a LG dryer door. On a difficulty scale of 1 - 10, it rates about a 2. Go for it.
Mar 06, 2009 | LG WM0642H Front Load
Door swing on a LG WM0642HW
Sorry on that model you can not reverse the door.
Dec 18, 2008 | LG WM0642H Front Load
LG WM0642H Front Load Logo
242 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
