Question about RCA D52130 52" Rear Projection Television
Words when we see the words they are alittle bit blurred. How do i fix that?
  • 975 Answers
Theres a FOCUS adjustment button , but not sure if its located in the front or in the back of unit ( im more familiarized with TOSHIBA models ) . you have to remove the front cover , or the back cover to access to it . hope this helps
Posted on Apr 28, 2008
NComputing WinXP does not linked with SAP 7.1 beacuse of graphical issues in all icons blur image.
The device can be configured for various resolutions and color bit depth up to 24b. Additionally there are settings for 60Hz and 72Hz monitor refresh rates. Play with those settings until the image is what you desire. I would fist start with the different refresh rates, that usually fixes blurred images.
Jul 30, 2011 | NComputing L230 Network Terminal
I had my 1994 mercury grand marqui parked in the driveway the other day and I needed to turn the steering wheel alittle bit to see something I did not start the car I just unlocked the steering column and...
DOn,t drive this. Open the hood, follow the steering shat to the gear box. there you will see a Rubber like connector that connects the shaft to the gear box. This is what snapped. Your car is really not safe to drive untill this is fixed.
May 22, 2011 | 1994 Mercury Grand Marquis
My hpdv6383ea screen is blurred the words n pics are
Easier to remove program then reinstrall.
If after install problem persists, card most faulty, if new inside year of purchase return to point of sale, with hopefully receipt or plastic friend statement!
Nov 10, 2009 | Computers & Internet
Tv is alittle blurry, its hard to read words
when its hard to read words its usually the sharpness which make the t.v.'s look either blurry or sharp or right in between. you can fix this by adjusting it thru your tv's menu either on the tv or your remote, look under the picture tab in the menu and there should be a sharpness adjuster there. adjust as needed
Oct 13, 2009 | Televison & Video
My RCA TV guide words is blurred but the
There are 2 things you try. go into menu to picture setup scroll down to sharpness,back this setting all the off. If this doesn't do it, go to back of the set on right hand side, if you can see focus slot adjust it slightly.
Sep 06, 2009 | RCA F25654BC 25" TV
Blurred words
I have a hard time to vision that it is just the words, is the picture blurred also? If you are inclined, you have to take the back cover off. With a medium to small INSULATED screw driver you will see a big transformer that has a HIGH VOLTAGE lead going to the picture tube. There should be one or two black plastic screws on it (hence the insulated screw driver use) adjust one or the other to see if picture improves. Will not take much adjustment, but must take CAUTION as not touch the metal part of the screw driver, we are talking 15 to 32K volts. Naturally the tv has to be on to do this.
Jan 18, 2009 | RCA F25654BC 25" TV
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
please give me a good rating if solution works for u.
Thanks for using FixYa.
Nov 22, 2008 | Yahoo YHT-630 System
My copies and prints are blurred with shadows
That was the Solution that the ink cartridge required a replacement
Aug 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Blurred words
have you tried to do convergence?
Jan 31, 2008 | Mitsubishi VS-50605 50" Rear Projection...
RCA D52130 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
