Question about Refrigerators
Frig part has gone to 46 dergrees and stays there. We just bought it only two months ago. If I put it on super cool it goes down to 34 but doesn't stay there
  • 725 Answers
Still under warranty call for service...
Posted on Apr 28, 2008
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
I have a 2002 buick lesabre and the water pump was changes about a month ago. The car ran fine. The last week, the car is temp gauge is reading hot very fast. I dont smell any coolant and it doenst sm
some times when the water pump is changed you gotta fill up the radiator with coolant, run the engine until it gets hot, shut off the car and wait until the car cools down to put more coolant because some air may stay trapped inside and by following this steps you get rid of the air trapped inside.
try this:
1) when the car is cool take the cap of the radiator off and see if it's full. if it isn't, with the car still off, put some coolant until it gets full.
2) once the radiator is full, start your car and wait to see if the coolant goes down the radiator. if it does, keep putting coolant until it doesn't take any more.
Hope to be useful.
Sep 07, 2012 | 2002 Buick LeSabre
We bought our frig exactly 6 years ago (to the date!) and suddenly the frig part is cool, but not cold, while the freezer section stay cold and ice is frozen.
Check your freezer section ! Is the coil frozen over ? If so it may have a burnt out defrost element or a bad defrost timer. When the freezer coil freezes over cold air is restricted to the refrigerator section.
Jun 03, 2011 | Refrigerators
Every Couple of Days water leaks out from under the freezer. I bought it from Home Depot about 2 months ago. What do I do now?
every 8 hours of cooling ( compressor run time ) which may be every cople of days the frig has a auto defrost . your unit may use a a d control so it may do it an any time it decides to defrost . when defrosting the water goes through a drain and under the frig to a holding pan . if pan is cracked or if drain hose is not in the pan it would leak .. it should be under warranty so i would call maytag and im shure they will correct the problem .. mope this helps mm ..majic **** ...
Oct 22, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
