Question about Kenmore 5230 Dehumidifier
Kenmore dehumidifier model 5230
After running it for some time, ice is formed over the filter. What is the reason and what is the solution?
  • Anonymous May 19, 2008
    have same frosting problem. tried all combinations settings but nothing works. unit is seven years old . worked ok last summer and fall. it is still pretty cold in basement. put a space heater nearby but after 5 days still no results. filter in back is clean.
  • Anonymous May 31, 2008
    Same problem. As soon as I start it up my dehumidifier it begins to frost up on the bottom of the coil. Is there any adjustment I can make to prevent this?
Have same problem of frosting. tried all combinations of humidity and speed settings. its still cold in basement so i fired up a small space heater. after 5 days still no results. seperate humidistat reads 83%. help please.
Posted on May 19, 2008
    Genius:
  • 1,073 Answers
The unit has a sealed system leak and needs pro repair call sears or a&e at 800-905-9505 for service
Posted on May 05, 2008
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Ice is forming on the top of the unit, it is running but not very much water is collecting
Ice will often form if the humidity level is high or the air intake filter needs cleaning. If it's because of high humidity or being used in a basement, the unit may appear to still be running, but it's usually just the fan and it's going thru a defrost cycle.
If you check the filter, be sure to turn the Master ON/OFF Switch OFF and unplug the unit. Remove the filter and clean if necessary. If you wash the filter, use warm water and dish washing liquid. Rinse thoroughly and allow to dry completely, before reinstalling it. DO NOT run the dehumidifier without the filter installed.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 20, 2011 | LG LHD45EL Dehumidifier
IS NOT PULLING WATER FROM AIR INTO DEHUMIDIFIER. IT IS ALWAYS EMPTY AND WE KNOW THE BASEMENT NEEDS THE WATER PULLED OUT
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
l;'';
Feb 23, 2011 | Kenmore 5230 Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Why is ice forming on the top of the dehumidifier ?
Sometimes when they run extended periods of time the outter case can get very cold also...with no air moving over the outer case the condensation can freeze there....
This is a tip that I wrote that will help to understand it better...
Dehumidifier is Freezing up and not working http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
heatman101
The dehumidifier freezes and ice forms on the filter in the back. It keeps running.
You are working it too hard. Back off the percentage. But first, let it thaw. Id be inclined to use a fan in the area. You might need two machnes in this space. Do not allow outside air into the space until you get it a little more dried out.
I hope this works for you
a
Sep 30, 2009 | Kenmore Dehumidifiers
Need owner's manual
You can get your manual from here:
http://www.managemyhome.com/mmh/owner_manuals/search?page=1&query=Kenmore+Dehumidifier
But first take a look at your model number to search for it.
Jul 12, 2009 | Kenmore 5230 Dehumidifier
Kenmore 5230 Dehumidifier Logo
230 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
