I am currently trying to put ink in printer - Office Equipment & Supplies
  • Anonymous Jan 08, 2009
    how do i put ink in my printer
  • 26 Answers
And the problem is..??
what printer is it?
Posted on Apr 28, 2008
How to manually unlock printer head position that is currently stuck in print head cleaning area.
if you see inside the printer there is a white gear in the left side . try to turn it front or back and move the cartridge
Feb 18, 2016 | Canon PIXMA Office Equipment & Supplies
I have put a tesco hp compatible ink cartridge in my hp 2050 deskjet printer but a msg comes up INCOMPATIBLE INK CARTRIDGES The cartridges listed above are not intended for use in this printer as...
This model Cprinter may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 26, 2013 | HP Deskjet 2050 All-in-One Printer
Ink not coming through, havnt used it for bout 2 years, i have cheaked and there is ink there but its not come through when im trying to copy
Since you mention ink. The chances are that the printhead is clogged with dry ink. To attempt to clear the clogged head, you will have to remove the printhead (remove ink cartridges, remove printhead from carrier). Soak the printhead in a bath of warm (not hot) distilled water overnight. After the soaking of the printhead, dry the printhead with a clean lintfree cloth (dab the printhead carefully so you do not damage the printhead or electronic contacts). Reinstall the printhead and ink cartridges and test. You may have to do this a number of times depending upon the amount of dried ink.
The alternative is to buy a new printhead for the printer. If you want to go this direction, let me know the manufacturer and model of the printer and I can help you find a supplier.
Let me know if you have any other questions. Thanks.
Jun 29, 2011 | Office Equipment & Supplies
X2550 ink problem, i just had it run out of black ink, so i put in a new black ink fromthem it's from their return program, however, it says that there is no cartrage! wat!? i tried to pop the old...
Try to manually wipe the black cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the black cartridge. If error continues, please contact Lexmark technical support for additional assistance.
May 30, 2011 | Lexmark X2550 All-In-One Printer
Model c309g. I replaced the black ink cartridges because of low ink. I am trying to scan black text and it comes out blank. Scan color and it comes out but obviously without the black. I have re-run...
Do you still have the old cartridges, if so did the blacks still put out some ink even just a dot or two. If so put the black cartridge back in and try a sample print. If you just get a mark or two on the paper it may mean that you are new cartridge is faulty.
Sep 11, 2010 | HP Office Equipment & Supplies
Hi my hp printer keeps say 3 on the screen and it says it out of ink but on the computer it shows us that we have enough please can you help thank you from Natasha.
Try unplugging the printer power from the wall for a good 90 seconds. Then replug it in. If it still shows needing new ink, try opening the cover to the printer, removing the current ink cartridge, then shutting the lid. Turn off the printer from the power cord again. Then plug it back in, turn it on, re-open the lid, and put back in the same ink cartridge. If it still has the problem and you are sure there is enough ink in the cartridge it sounds like the printer sensor has an issue.
Sep 09, 2010 | HP DeskJet F380 All-In-One Printer
Will a hp 96 ink cartridge fit a hp psc 2350 series all-in-one printer? Thank you, Kathy Litch
When I put my #96 into my pcs 2350, the printer then tells me that the ink cartridge is not for use in that device. I went to the hp website and when clicking on the link for approved ink cartridge's, the #96 is not there. I'm currently trying to find a way to figure out how to make the device "accept" it, because there is plenty of room for this cartridge and it 'SHOULD' work. After all, in the store I purchased the ink from (best buy), they said it would work also (i threw away the receipt of course).
Dec 08, 2008 | HP Office Equipment & Supplies
Epson c43sx current ink levels not shown in the properties
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Ink Level refresh for POS Jet 1000
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 19, 2008 | Office Equipment & Supplies
83 people viewed this question
jasbo
jasbo
