Question about HP DeskJet F380 All-In-One Printer
Printer won't work
Cannot get my printer to work on my computer it is acer and it is vista
  • lagi Apr 28, 2008
    I can't installed it "it give saying it does not support 32 bit operation"
  • Anonymous May 08, 2008
    lost the cd
    Problem Solver:
  • 9 Answers
Try to install the printer again on ur computer. Try these steps to install the software on ur computer again. 8 out of 10 times, it works, so try this:
  1. Click Start and then Printers and Faxes .
  2. Follow the steps in the Add Printer Wizard to add the print driver. Select HP from the list of manufacturers and then locate the all-in-one printer driver or fax driver (if your model can send and receive faxes from the computer) from the list of printers. The models will probably be near the bottom of the list.
  3. The printer port should be selected as the USB001 (Virtual printer port for USB) or the DOT4_00[x] HP (all-in-one series) printer port if the first port is not an option.
  4. Select the option to Keep existing driver when that choice displays.
  5. If prompted for a missing file, have the installation search for the file on the All-in-One CD-ROM.
  6. The installation should complete and a Congratulations screen should appear.
Thank u.
Posted on May 28, 2008
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
I have an acer computer with windows 7 try to set up my hp laserjet 1012 but won t let me install
It depends on how old you HP printer is,you may need to replace it.I had an older HP Scanner a few years ago and would not install on my new Windows Vista machine,just not compatible.
You may want to contact HP to see if they can help.Their costumer service is great and fast
Feb 09, 2011 | HP Office Equipment & Supplies
Acer aspire one notebook model ZG5
If your computer is Vista, it's asking for the system disk. If it isn't a Vista operating system, you're trying to install the wrong driver. You can download the correct driver here.
Jun 18, 2010 | Acer Aspire One PC Notebook
Printer DeLL AIO 922 is not accepted by Acer with vista premium
You will have to uninstall all the old drivers first as the pc will use those first then re install new driveres from dell
Sep 06, 2009 | Dell 922 All-In-One InkJet Printer
NEW ACER COMPUTER WITH VISTA INSTALLED...NOT ABLE TO PRINT
make sure your printer driver will work with vista.if not update the driver
Jul 18, 2009 | Brother MFC-640CW All-In-One InkJet...
CAN'T INSTALL LEXMARK Z600 PRINTER ON ACER LAPTOP
If the disk does not work, you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Jan 25, 2009 | Lexmark Z600 InkJet Printer
Installing driver for HP Deskjet 1520 on Acer Aspire with Vista
i recommend an uninstall on the printer software..update the operating system with all known bug fixes, then download a fresh driver set..
Nov 21, 2008 | Office Equipment & Supplies
I have just connected a HP Deskjet 3940 to my new acer computer and it is not printing. I went in print then options and clicked on a few things but still not working. Have new cartidges in 22 and 21
un install the printer driver,reboot ,windows should detect new hardware ,and then insert the cd that came with the printer select have disc and re-install the software.
if your acer has vista you may need to get a vista driver for it,or worse the printer is not compatible with vista.
good luck
Terry
Mar 12, 2008 | Computers & Internet
Acer Aspire and Lexmark 640
mayba your printer driver that was in your cd is not compatible with windows vista.. try to download a new printer driver that supports windows vista from the manufacturer's site. then try to install it.. this would help you out..
Jan 22, 2008 | Acer Aspireā„¢ T180 PC Desktop
Connecting the scanner to a new computer with Windows Vista
If the Acer has an parallel connection and not USB this indicated to me it is an older machine from the Win98 era. In which case it will not work with Vista. Indeed many newer devices do not work with Vista there is a real issue here Check back with Dell on this.
Jun 09, 2007 | AcerScan 620P Flatbed Scanner
HP DeskJet F380 All-In-One Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
