Question about Maytag Performa PAV2200
Maytag mindryer DE 50
Hi ! I have a similar problem. The dryer heat was working and the drum was turning but the clothes were not drying. I took the back off and found the fan belt was broken. So I replaced that and while the back was off I decided to clean up the dust build up on the fan, the inside of the cabinet and in and around the motor. I used q-tips wetted with wd40 oil to catch and pull out the dust from the motor. Anyway got everything back together but the dryer would only run if you kept your finger pressed on the start button. So I don't know if I bumped something when I was cleaning? Also there was some smoke from somewhere. I wasn't very thick. I think it might be from the wd40 burning off the motor? What do you think?
  • 1 more comment
  • jiffy helper Apr 30, 2008
    I went and took the back off the dryer to check if there was friction with the new belt that I put on and found that there was a section on the belt that has melted some. It was frosted or milky looking versus clear plastic. The cross section of the belt is round versus flat and the melted part was a little thinner. There are two wheels that the belt is stretched around . The one attached to the fan on the dryer drum is black plastic and the one of the motor is metal . I figure that the heat must be generating from the motor. I checked the broken belt that I replaced and it had a very slight melt spot where the break was. So I think I found the problem. My question is now - can the motor be overhauled or should I just replace it?
  • Anonymous Jun 09, 2008
    i just bought one used for our apartment...the belt moves and the drum spins (I can feel the heat and the clothes do dry) but it seems to be running very quietly for a dryer. There is no air blowing out of the vent...is there a blower that should be moving air? If so, is there any problem running the machine without the air moving through?
  • uofallb08 Jun 09, 2008
    I posted the question about the lack of air movement through the machine...FollowUp: I just hung a piece of thread at the vent at back of machine and there is some movement of air but very weak. I'm wondering if it's just air that is being forced through as a result of the drum spinning. Should the air coming out of the back be fairly forceful or is this normal?
  • 868 Answers
Replace it ,its known to weaken after awhile,remember this W-D 40 is very flammable ,NEVER spray it near anything that can spark.Also never oil a appliance motor it will only mask the problem for a short time and alot of times it will smoke.Self lubricating bearings are not to be oiled .I'll be happy to guide you through any repairs you need.
Posted on May 23, 2008
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Not getting hot to dry. My dryer is not drying the clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Maytag Performa PAV2200
Dryer drum rotates but no heat to dry the clothes. Happens occassionaly and then dryer seems to work ok.
burnt or loose power supply cord at the point it attaches to your dryer. also may have a clogged vent.
Oct 31, 2009 | Maytag Performa PAV2200
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Dryer not drying clothes
Check your heating element your lint trap and your exhaust hose.
You can check the element by opening the door pushing in on the switch and turn it on,you will feel or see the heat.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 18, 2009 | Maytag Performa PAV2200
Nextra7 condenser dryer making squeaky noises
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
Feb 14, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washing Machines Logo
395 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
