Question about Kenmore Washing Machines
Kenmore model # 110.24972300 Type : 111 There is a "whirring" sound when all movment cycles run and when it finishes the agitation and starts to drain - the agitator and tub start to move (almost a ****) and then they do not move - if I lift the lid for a second or two and close it again it starts spinning - the "whirring sound is louder when it spins. Could this be the clutch?
  • 183 Answers
SOURCE: Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Posted on Dec 25, 2007
  • 1073 Answers
SOURCE: Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Posted on Apr 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
Posted on May 20, 2009
  • 82 Answers
SOURCE: Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Posted on Jun 14, 2009
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
I have a Kenmore washer model 110.26422502 Type 111 that stopped running after filling the tub on normal wash. The machine will not agitate, nor will it drain if I turn the cycle knob to rinse. I've...
This is usually the lid switch. Check for continuity, you should have continuity when lid is closed none when lid is opened. Use a screwdriver or similar to trip the switch. For a video on replacing a similar style go to www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Kenmore Washing Machines
Washer Kenmore 70 Series Model # 110.247323000 Serial# CR3845255 Type 111 Washer fills cold, warm, hot - no agitation - no draining
IF THE MOTOR DOES NOT RUN CHECK THE LID SWITCH. IF YOU HEAR IT RUNNING YOU MAY HAVE A BAD COUPLER.
Jan 12, 2010 | Kenmore Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
257 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
