Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo 73 don't work
Have had my stove for 10 years with no problems. The power was off for 14 hours yesterday and when the power came back on my Toyo wouldn't work, has a code of EE8. Any ideas whats wrong. Darrell
  • Tesse Oct 04, 2008
    Stove worked fine until it was shut off for the summer. Now there is an EE8 code when we try to restart.
  • 57 Answers
Take a look at this...
http://www.rural-energy.com/publications/catalog/document/338
This site says there is a problem with the blower motor assembly.
Posted on Oct 19, 2008
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
Jun 09, 2011 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73 displays ee 10. Toyo is brand new, no obstructions in flue, fuel tank is a good height, only pressed red button once for a second, blower fan works.
ONCCON,
EE10 is not good. This means you had a flame in the pot when there should not have been one. The red button is to be used very carefully. One time for one second. I think you have pushed the button too much and got a fair amount of fuel into the burner. Without pushing the red button try the stove again. If you burn out the fuel in the burner the stove will operate normally. If the code continues I would look at the hook up for the air and exhaust to be sure they are correct. If they are backward it can cause an EE10.
Keep us posted,
Tom
Jun 01, 2010 | Rinnai Toyostove Direct Vent Heater:...
I need to get replacement parts for my laser 73 stove and no one around seems to carry them? Any ideas?
Any dealer that sells new Toyo stoves should be able to help you.
I don't think the rules of this site will allow me to post the web address of the dealer I use; but typing "Toyotomi heater service" into Google pulled up quite a few dealers.
Hope this helps!
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove ventilation
Alaska Cat,
No this is not right. You can remove the air hose for a short time until you can get another part, i.e., new flue pipe. The stove tech should have told you he would be back with a new part. As far as the igniter is concerned it could be replaced without removing the heater. Now, if you had flooded the unit trying to start it many times your mechanic might have had to take the unit out just to be able to clean it completely.
Stay warm,
Tom Hawkins
hawkins111@gci.net
Apr 01, 2009 | Rinnai Toyostove Direct Vent Heater:...
We just got oil after not using our toyo stove since last Summer. when I turned it on and push the on button it flashes 12:00 then a second push of on button briefly shows temp then goes to EE8, I can't...
Ok so I bought a L 73 model two years ago and today I had fuel delivered in prep for the winter. When I turned the Toyo on it waited about 5 minutes before giving me an EE 08 error message. The manual showed blower motor trouble and I was bummed so I called a friend. He gave me the following information he learned from a Toyo dealer as a "temp" fix until a more thorough cleaning can take place. Apparently stuff (crusties, ash and burnt debris) have a tendency to build up around the blower motor fan which causes it to get stuck. This is not the large visible fan on the back, but the smaller internal one. There is a rubberized hose leading to the larger fan and a smaller flexible stainless exhaust next to it, which is the one I was told to remove. Once you remove the flexible exhaust get a flashlight and look into the back and you'll see the fan (or only about the 1/3 of it which is visible). Take a pencil eraser and gently remove the build up between the exhaust slats. I also used my craftsman shop vac which fit nicely right over the hole to remove the debris. Once you have all the soot, crusties and stuff removed the fan should be spinning at warp speed when you remove the shop vac. This took my literally about 10 minutes to disconnect, clean and reconnect. About 8-10 minutes later the unit was working great! Hope this helps anyone having similar problems.
Feb 19, 2009 | Rinnai Toyostove Direct Vent Heater:...
Do not buy a Toyo in Fairbanks.
You are right. The "service" in Fairbanks for Toyos is almost non-existant. My company has been tuning and servicing Toyos for over 12 years here in Fairbanks. We have tried to get a dealership but the main company, Toyo USA and the regional rep., REE refuse to allow us to be dealers. We have tried several times over the years. We buy parts in bulk from outside sources and pass the savings onto the customer.
A letter to Toyotomi or Toyo USA will not work. They don't care.
There is one person with a van that will "Tune" a toyo in your home. Don't use them. It is not possible to properly service a Toyo in your home. There is fiberglass and creosote dust that will get everywhere weather they use a vacuum or not. That's assuming they even clean your burner pot. Our company was started because of this poor service in this town. We operate by word of mouth only and have about 2 dozen regular customers.
Jan 08, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Lazer 56
Hi EJAKFbanks,
I believe by your description and my 8 years experience with Toyo Stove repair that you are missing part of the firing sequence. The firing sequence for a Toyo Stove L 56 is to blink on the burner light for 7-9 minutes, then it clicks up to the medium light (amber-yellow color). The medium light blinks and that is when the fuel pump kicks on and starts to pump. If the stove ignites, the medium light will glow for a second and then drop down to the low light (green) The low light will burn for awhile and at this time you will see a blue flame in the newer heat chamber models or a red glow, and perhaps some blue flame in the older heat chamber models, then the stove will kick up to the medium light for a bit, and then to the high light. An EE6 error code will show only when the flame is extinguished after actually taking place and a burn did occur in the chamber on low. An EE6 is usually one of 2 things: 1. There is an inadequate fuel supply for the stove to maintain a low cycle burn, or the medium, or high. Each cycle consumes more fuel than the prior one. Inadequate fuel supply can be due to a restriction in the fuel line such as icing like cholesterol in a persons arteries, or a plugged sump screen, blocked fuel line or filter, too low a quantity of fuel in the tank, or a fuel line that is not all gravity feed, as in, the fuel line runs down, down, and then up a few feet to get to the Toyo. In that case, the fuel has to rely on head pressure to get to the stove. Head pressure is the atmospheric pressure pushing on the fuel in the tank to force it up against the earth's gravity forces. Solution: You can find any restriction in the line, replace the filters, clean the sump screen, put heat on the fuel line to thaw any icing blocks. 2. An EE6 can be caused by a carbon chain developing from the burner ring, flame sensor or chamber wall to any metal part in the burn chamber. A carbon chain essentially "shorts" out the ground for the unit and the Toyo will shut off on EE6. Solutions:You can bang the side of the Toyo (Old frustrated Alaskan solution) which really just jars the carbon chain loose, clean the flame sensor, clean the fuel nozzle with a straight 3 inch wire, and stick a screw driver in the igniter (red wires) hole and rattle it around real good (another old Alaskan trick). Often, those three things will get your stove running again if it is a carbon chain. The problem will likely occur again, but it will buy you some time until you can get a tune-up done. Most likely, you need a tune-up. Question: When was your last tune-up? Toyo's should be tuned up every 2 years. Tthe book says every one year, but in my experience, every two years is the best bang for the customers buck. The three year mark usually begins showing signs of metal fatigue in other parts of the burn chamber/heat exchanger system so the costs rise a little each year, unless you are a lucky Toyo owner and for some odd reason, your stove can go 3 years between cleanings without any ill effect. If you get your stove running, run it hard on High for about 2 hours to clean and burn all the carbon out. Good Luck! toyotech, North Pole, Alaska
Feb 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
468 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
