Question about Black & Decker ProFinish X750 Iron
How to clean the plate of a black and decker iron that has build up?
  • 975 Answers
I suggest to purchase a bottle of CLR , at any mega store (WAL , K ...) HOPE THIS HELPS , THANKS
Posted on Apr 28, 2008
  • 487 Answers
You can take the solution for descaling coffee machines and set the iron in a layer of less the 1/4 inch deep.
you can clean out the holes with a needle. than run the selfcleaning cycle.
leave the sole in for about 15 minutes. Than clean with non scratching scotch brite.
How do i remove a black smear on my sole plate icr 500
clean it with a sharp edged blade slightly ,only when it is hot
Nov 13, 2014 | Black & Decker ICR200 Iron with Auto...
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
Water shoots out when trying to steam.
You are getting a lime (scale) build-up in the iron. Best to try a clean, either with a self-clean function, or buying a lime remover solution for kettles and irons.
Dec 09, 2010 | Black & Decker D2030 Iron
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
Cleaning an iron faceplate
first you get the iron hot,
then you use a damp towel,
and rub firmly
Oct 06, 2009 | Black & Decker Irons
Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Aug 19, 2009 | Black & Decker D2030 Iron
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
How to clean inside of Iron?
Unplug the iron! Allow iron to COOL completely!!! Wipe soleplate with damp soft cloth or damp soft sponge. NEVER use abrasives, cleansers, scouring pads that will scratch iron and cause discolorations. The iron has an Auto Clean Steam Valve feature that will prevent most mineral and lint build up everytime you turn the Temp. Select Dial to "0" after use. (Ref. - page 11 of the instruction pamphlet). If you have a really bad hard-water build up problem, use a commercial Steam Iron Cleaner and follow the instructions exactly! Repeat every 3-6 months and you should be fine. Good luck!
May 04, 2008 | Black & Decker Quick N Easy X420 Iron
Melted material on face of iron
Yes- I had the same problem and could not clean it off. It was a plastic sticker that melted on the iron plate- placed there by the manufacturer. I called Customer Service at Black and Decker, and after all their solutions failed- they sent me a new iron. But this one leaks water terribly to the point where the clothes are soaked after only 1 or 2 articles are ironed! I am beginning to lose faith in Black and Decker products.
Dec 24, 2007 | Black & Decker D2030 Iron
Black & Decker ProFinish X750 Iron Logo
173 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
