Question about Lexmark X1240 All-In-One InkJet Printer
My computer is not communicating with printer.
Ive printed many times and it worked perfectly.
but sometimes it just wont communicate properly,and says problem communicating with printer.ive checked the power and usb and its all working fine.i think it might be somthing to do with windows Vista but im not sure.Please help i have a project due tomorrow.
thanks,
Greg.
  • 1 more comment
  • Anonymous May 10, 2008
    printer stopped worki
    ng. It will start then will freeze, but all in one says that everything is ok.
  • Anonymous May 16, 2008
    Lexmark x1240 trouble communicating
  • Anonymous May 19, 2008
    I have a Dell Inspiron 530S Vixta and a Lexmark X1240 and it will not print. The message is" problem connecting with the printer."
    Genius:
  • 2,035 Answers
This is the problem with the antivirius or firewall please disable them during printing......................
good luck..............
Posted on May 06, 2008
Wireless printing problems
It is due directly to the strength of your connection. It must receive all components (packets) of the communication in order to print. IF NOT then it wont print. You need a stronger signal or wire your printer directly to the computer. Good Luck!
Jun 05, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
I get a message saying the printer cannot communicate with computer. Everything is connected properly. Also, the wifi light is flashing. Sometimes it prints, but it randomly cannot...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Unplug and re-plug the printer into the power source to reset it. Reboot your computer.
You may also refer to this article found in the Lexmark website: How to identify a Wireless Communication Problem and Resolution Tips.
Jul 13, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Printer does not print when I send from my computer, but does print when I place copy under screen for copying.
Copying and printing are two different functions. Your machine will process copies because the work is all done AT the copier. In order to print the PC and the copier need to be able to communicate properly.
Make sure that the printer drivers for your machine are set up properly on your PC and the two systems are communicating correctly.
Aug 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink wont print or prints with blank lines through words
Hi! In your case try to change the printer port in the printer settings. I think the only problem you have is the communication between the printer & your computer. pls check. GOOD LUCK
May 15, 2009 | Microsoft Windows XP Home Edition
I just put new ink Cartridges but still wont print
Most of the time the "problem communicating with the printer" message pops up on Lexmark X1185 series when the driver gets corrupted. The best fix for this issue would be to uninstall the software first. Try connecting the USB to a different USB port (Please avoid using USB hubs, if any) and then reinstall the software. This should normally fix the printer communication issues!
Good Luck
Dec 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
PRINTER BROTHER DCP-110C UNABLE TO PRINT. IVE CLEARED PAPER JAM, STILL WONT WORK. LEFT UNPLUGED FOR 30 MINS STILL WONT WORK
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Dec 06, 2008 | Office Equipment & Supplies
Dell printer power button flashes
no the printer is perfect , but many times this error occurs after changing the cartridges.
first remove all the external connections from the printer.OFF the printer remove the power plug.hold for a minute.then plug the power cord and then ON the printer ,connect the printer to the computer by USB wire as regular.and then check by giving printouts.if it still shows the same error.
then try this
thanks.
Oct 23, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
137 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
