I keep getting disconnected from the internet
  • 88 Answers
Check your internet cable for loose connections, If you are using Windows XP, try the following methods:
1. Go to the Control Panel; right click on the Network Connections.
2. On the dialogue box, click Status; the Local Area Connection Status will appear, check if its is connected or not. If it is connected. Unplug the power source to your internet cable/connector.
3. Restart, your computer;then re-plug your internet power source.
4.Wait for at least 30 minutes then check your browser.
5. If there is no internet signal, you should call your internet provider's technical service.
Posted on Apr 28, 2008
Why does my lg650 smart tv keep disconnecting from wired internet
What is the actual model number of your LG TV, this would help. Also when you say keeps disconnecting, do you mean whilst it is on and functioning, or do you mean after it has been switched off?
Nov 22, 2014 | Televison & Video
Tip
Internet keeps disconnecting - Internet disconnect
Having intermittent internet disconnects? There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. If you have a modem that you bought that was not provided by your ISP, you can try to update the firmware on the modem.
If using a modem
I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
I would also recommend that you update your router firmware as well. Do a google search for the brand name of the router and go to the companies website, look in the support/downloads section for updated software.
--If possible, try a different Ethernet port on your router. You may have a bad port.
--Take out and reinsert all Ethernet cables on your network. Loose cables can cause disconnects.
--If possible, replace the Ethernet cables. Bad cables can cause this.
Lastly, you could be having an issue with the Network card(NIC) on your computer. Network cards are either built into the modem or external(a card you insert into the motherboard). Using the process of elimination and the steps above, you can hopefully narrow down the problem to one specific component of your network.
Regards,
G33k
Keywords
Internet disconnecting, internet keeps disconnecting, internet disconnects, internet not staying on, internet shuts off, internet keeps shutting off
on Jun 14, 2011 | Computers & Internet
My router disconnect frequently
Question: the connection to router disconnects OR the internet disconnects,
If router disconnect: then try being in range, choose a better spot, keep router in a good spot,
If internet disconnects, cal ISP get it checked, make sure you run ping test to make sure its consistent , here is an example,
E.g:
open run: type cmd, hit enter,
type : ping google.com -t
hit enter, it should give regular pings without timeouts....if too many timeouts, internet service has issues,
call them and report..
Nov 29, 2013 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
Internet disconnects
It would seem as if you have a problem with your broadband bandwidth. You may need to add more RAM to allow the computer to buffer the video in the background.
Jun 28, 2013 | Computers & Internet
Keep gettin disconnect after 20 min even with fone line disconnected
if you keep getting disconnected then i would do internet test,if theirs no fault your end then i would contact your internet provider,because has long has its not xbox live which i dont think it his then i would ring your internet provider,also let us no more details has in does your internet go down or just xbox live? does your router or modem light go off every 20 mins then quickly come back on?
Nov 23, 2010 | Microsoft Xbox 360 Console
Internet keeps disconnecting. i have 3 internet dongle. worked fine for ages but now it disconnects then reconnects.
make sure the system is clean ... i see it everyday do this...
download MalWareBytes " malwarebytes.org get it install it ... upodate it full system scan .... use the trail version it wont expire you just have to manually update it ... i clean about 12 systems a day with this product....
Dec 27, 2009 | Microsoft Internet Explorer 7
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Mar 14, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Disconnection problem
have you configure your netgear wg111v2
Oct 02, 2008 | Computers & Internet
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
