Question about Peavey CH1 Speaker
I need replacement 8" drivers for my Peavey PRM 308S Monitors. What would you recommend?
  • 975 Answers
Heres a couple of links to get your DRIVERS replace ,
http://www.speakerrepair.com/ocsdiaphragms.html or
http://www.peavey.com/products/browse.cfm/action/drill/cat/4/begin/1/Accessories.cfm
good luck , please rate solution , thanks AJ
Posted on Apr 28, 2008
    Genius:
  • 1,689 Answers
You have to use original manufacture parts if you want the orignal sound and specs. The crossovers and design of the speaker enclosure is matched for the speaker drivers. Start at the link below.
http://www.peavy.com/
Jerry G.
I have an XR8300, two JBL 515XT (powered) for front of house and four 8 ohm passive boxes for monitors. What is the best way to connect all these to the Peavey mixer. Kaz
Feed FOH from Record Out, left and right. Feed monitors from the main outputs. That will give you the best option.
Aug 27, 2017 | Peavey Music
How do i hook up monitors to peavey 8300 mixer
Make sure main monitor switch is pressed in, look at back of unit, the speaker jack labeled main/monitor is now monitor output, you may use 2 8 ohm speakers, use controls on front labeled monitors.
Jun 27, 2012 | Peavey XR 8300 8 Channel Powered Mixer
How do i hook a peavey fx24 mixer to a Peavey xr8600 with out going through the 8600's mixer? I am wanting to use the 8600 to power my mains and use another amp to power my monitors. can i do this?
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Sep 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
How do i connect 2 monitors to the one monitor output jack on the peavey xr 600c mixer..cheers My product not quite the one as listed from your product database but may be similar
The monitors will have to be POWERED monitors with built in amps.
You can simply use a wye splitter cable to drive the two monitors. Run the cable from the mixer to one monitor and put a wye cable and an extention to the second powered monitor speaker.
Jul 25, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey Horn Drivers (compression drivers)
Did you sort your problem? I need 2 also, but seems quite easy to get 4ohm but 8 ohm a little harder. The woofer in the cab is 4ohm, cabinet is rated 4ohm so wondering wether to replace th 8ohm horn with a 4ohm diaphram.
Any thoughts?
Thanks.
Nov 26, 2009 | Peavey Audio Players & Recorders
Horns don't work on sp2 speakers
I've got Peavey SP2's and SP4XT's and they have one common problem. The 22XT Driver needs replacing from time to time. It could be a power spike, overdriving from amp, over heating or dirt/water in horn. The driver is very easy to replace and costs about $40.00. Remove the horn, carefully lift the horn and disconnect black and red wires. Remember red is always +. Remove driver from horn with socket wrench or socket screwdriver, clean the circular gap on horn with masking tape to remove dirt, hand tighten driver screws, connect red and black wires, carefully set horn back in SP2 enclosure and slowly bring up the power. Also be sure to be very careful when setting the new driver/ coil in the horn. You don't want to damage the coils on the new driver at all!
Jun 02, 2009 | Peavey CH1 Speaker
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
Peavey CH1 Speaker Logo
237 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
