Question about Sony Cyber-Shot DSC-F717 Digital Camera
DSC-F717 ON/OFF Switch Broke
I managed to break the plastic tab off the on/off switch. Can I buy a replacement part and fix it myself? (I've been looking around for parts without much success.) Thanks -- Frank in NY
  • 231 Answers
Andrews electronics or send to alamo camera service .com
Posted on Jun 24, 2008
KDS55A2020 - Replaced Bulb., now blinks red three times
Read all the recalls and the class action lawsuit over this issue in these sets that was settled and ended last year.
The safety switch is there only to prevent the lamp from being able to turn on if door is open or removed, thats it.
You have really solved or answered your own question. 3 blinks is the door is not closed or is warped from all the heat, the safety switch in your case seems MIA, going to have to find it first, it is usually a blue lever type and I suspect the plastic tab is likely missing from the door.
I would order the door and find the safety switch, it did not just walk away.
You might also be interested to know a lot of these got so hot they fused the door to the cabinet or melted the enclosure around the lamp, had two where in order to get door off had to use a Dremel cutting tool, Sony paid for all this even though set was out of warranty.
Find the switch and if snapped off or melted it and the door will both have to be replaced.
The only reason to bypass the switch is a simple one, TO KNOW IF THE SET OPERATES WITH IT DONE---no long term use, just to know the issue will be fixed.
Dec 22, 2012 | Sony KDS-60A2000 60" HDTV
Power switch stuck down on my Sony DSC-600 digital camera , can I fix this?
The power switch on this camera breaks in half sometimes after a while. Either replace the entire central plastic band of the camera on which the power switch is located or . . . . You can drill a small hole in the plastic and use a paper clip to turn the camera ON and OFF. A bit of a Rub Goldberg fix but it works. See picture for location of the hole. It lines up with the small switch on the circuit board. 0d405cb.jpg
Aug 25, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Door ajar warning on 1998 lincoln continental
just do some shots of WD-40 in the door latch. Three good shots, then open and close door about 30 times. and while you're at it, do it on all of them. I had the same problem. Fixed it in about 5 minutes.
Nov 21, 2009 | 1998 Lincoln Continental
2003 altima cruise control button broke off.
I've had the same problem on a 2004. The SET button has popped off for the second time now. Last time I bought the cluster and repaired myself. Hey, plastic parts break but my complaint is that Nissan should supply a $5 plastic button that would just pop in the spot where the old button was. As is you must buy the whole control cluster. That's just wrong!
Apr 13, 2009 | 2005 Nissan Altima
Battery fully charged but my Sony F717 just unable to switch on.
Problem is occour in camera power supply section. There are 4 fuse in BT-015 Board if they are okay than check FR-194 Board. on this board IC001 DC control is faulty. I hope problem will be solved
Oct 09, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
DSC-h1 Shutter button broken
I recieved my new shutter button from Sony and replaced it after searching on the net how to do so. I used rubber gloves to get a good grip on the button ring and turned it, I believe clockwise, and then replaced the it with the new button and ring. So simple and saved myself a lot of $$ though, $30 seems an awful lot for such a small piece of cheap plastic.
Sep 04, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
DSC-F717 On/Off switch Jammed
Greetings CarolineV
I have the same camera, and bought it about 5 1/2 years ago. Last fall I went to an outing with my family and spilled a small amount of coca-cola on the top of my camera. I immediately whiped it off the top, but some of the liquid got under the on/off switch and almost glued it shut. I asked my brother-in-law (an electrical engineer) what I could use to clean it with and that would not short-out the electronics and he suggested lens cleaner from a quality camera shop (which is all alchol based and therefore not going to short-out the electronics)
After about a week of putting a couple of drops directly under the switch every time I used the camera, it finally stopped sticking and now works perfectly. Not sure what is causing your problem, but you may want to try the same treatment and see if it helps - it won't hurt the camera, etc.
Good Luck!
Mike C.
Jan 07, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
DSC-F717 - "stucked" in nightshot mode
Yes you are right, it is more than likely the nightshot button that has shorted.
This is button is part of what we call the Switch control Block.
Phone your local Sony service Centre and ask them how much it would cost to replace the switch control block. My estimate is about a 1/5 of the original cast you paid for the camera.
Good luck.
Sep 24, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot DSC-F717 5.0 Megapixel
Hi Bella
That code means that the lens unit was unable to move from home position to switch on position.
These lens are extremely complex and I doubt if you could find someone able to repair the lens.
Therefore I suggest contacting Sony to find a accredited dealer to quote you on replacement of the lens.
My guess is it will cost half of what you originally paid for the camera.
Good luck.
Sep 06, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
87 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
