Question about Vacuums
Kenmore Progressive canister
The roller does not turn. The motor still runs alright.
  • natalieg1962 May 21, 2008
    The brushroll on my vaccuum isn't turning either. I've checked and ensured all hair/threads are removed and there is no belt (it's a beltless vacuum), any other suggestions on how to fix would be appreciated! I have a Kenmore model 116 31912103. Thanks!
    President:
  • 1,673 Answers
You are right, there is no belt on this model. First check where the hose plugs into the bottom, on some of these models there is a switch that turns off the brush roll when the hose is not there. There is an actuator that when you insert the hose, it pushes against the switch turning on the brush motor. It may be broken. There are also other switches and a circuit breaker. The top cover will have to come off to check the other switches and motor, wich is partr of the brush roll. If you go to sears.com, click on the parts link, put in you model number, the next page will give you options to click on and then you can see a parts list and a picture breakdown of the different sections of your vacuum.
Posted on May 26, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552407
Generic problem for all Vacuums
Posted by stupe on Apr 28, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a broken belt or a bad brushroll and either one should be replaced. If the belt is a flat belt, then the belt change is every 4 to 6 months and the extra belt stored in a Ziploc bag in the refrigerator. If it is a geared belt then you would change it every year or so depending on wear and how much it stretched. Also the brushroll should spin freely and check for no thread or hair buildup on the ends and on the brushroll itself.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
How do i reset a sears cannister vacum cleaner
Hello, you can not reset the canister only the power head, if y ou picked up something and it got caught in the roller, it will shut the motor off, on top off the head is a red botton take a pen or something small to push the botton, and that will rest the powert head, if the canister is not running the cords go bad, and will need to be replaced. If I can help, feel free to call 1561-848-3387 Thank you, Teresa.
Clean Sweep Vacuums
Aug 10, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Roller does not turn; I was vacuuming a rug and a string got stuck in roller-took it off but now the roller will not turn. suction is fine.
The roller drive belt may be stripped, worn partway through where it goes around the motor shaft, thrown off the motor shaft, or broken. Take the bottom plate off the carpet sweeper and have a look.
If the belt was damaged when the roller brush got stuck, then you get to replace it. On most of these, the easiest way is to put the new belt around the roller pulley, reinstall the roller, stretch the belt around the end of the motor shaft, then turn the motor by hand while pushing the belt on. If the motor also has a pulley on it, you may have to remove the motor screws to get enough slack on the belt, then pull the motor into place and put the screws back in.
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Carpet function rollers don't turn
Most likely a broken belt. If the brush roll is turning freely, then check the belt.
Mar 02, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Vacuums Logo
262 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
