Question about Saeco Magic Cappuccino Espresso&Cappuccino Machine
Message showing brewunit missing - Saeco Magic Cappuccino Espresso&Cappuccino Machine
  • supersonic08 Jun 03, 2008
    I have the same message on my saeco magic comfort machine...Brewunit missing but i can still make a coffee... very noisy unit is this normal...?
    can you help
    thanks
  • 515 Answers
If you take out the brewing unit and look in to the chassis, then you see a little sliding hole. If you take a lamp you will see a little pin in the hole, if not the micro switch has to be replaced.
Posted on Jul 12, 2008
2 Suggested Answers
  • 4 Answers
SOURCE: MESSAGE SAYS BREWUNIT MISSING CANNOT CLEAR
Try taking the brew unit out, and clean the area inside the machine for coffee grains before reinserting it. There's a tiny sensor for if the unit is inserted, but it can be confused if the machine gets messy inside.
Posted on Oct 23, 2009
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
The brew group is stuck and won't come out.What to do?
Hi. Its not an easy fix. The brewunit is stuck in cycle, with the injector pipe holding it in. The injector pipe is at the back behind the brewunit. You just need to use force by wriggling and jiggling the brewunit. There maybe some screws in the brewunit, that may help you if you undo them. If you do get the unit out, then you have to work out WHY it has not completed the cycle, so when you put the unit back in, that is not going to get stuck again. Ive spent 30 mins getting out a unit, only for it to get stuck again. For some reason, its easier to get the brewunit back out the second, or third time you try it.Sometimes you may have to break something to get it out. Id recomend taking it to a repairer and let them work it out. It can take hours of work and care must be taken, not to do too much damage. Even disassembly and reassembly or the outer panels canbe a challenge on these models. Saeco are a good machine, but are a dumb design when ti comes to stuck brew units. Sorry I cant be more help with this problem, but I hope its just a soiled brewunit, and once you've removed and cleaned it, It'll work fine again. Weekly cleaning tablet should stop it from happening again. Dazza
Oct 21, 2011 | Saeco Odea Giro Plus Coffee Maker
No matter what I do the Gaggia Titanium espresso machine reads brewunit missing;. This is what I did: I removed the brewunit of the machine to clean it, and reset the N to the correct position on the front...
HI
If the brew unit is in the wrong position when inserted you can knock the lever off the microswitch in the back. If the lever is knocked off you will never get the brw unit miss message to go away. You will have to take the machine apart and replace the lever on the microswitch. Sorry
We made a modification to the brew unit that would prevent this from happening. We modified all the brew units on the compact machines before sending them out so we would never get them back for this reason.
Apr 26, 2011 | Gaggia Titanium Espresso Machine
Hi, I have a Saeco Magic Comfort coffee machine which displays the following message when I switch it on 'Brewunit missing'. Hope you can help. Cheers
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed(food gade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
My brewunit is blocked
Coffee fines and mineral scale build up in the brew unit filters and also in the creme valve. The pressure to pump water through the unit fails and the flowmeter tells the electronics that no water has flowed, it in turn stops all processes and displays "brew unit blocked" message. If you're handy, call Miele tech support. The'll walk you through how to remove the drainage cup screw off the left rear of the brew unit, get the brew unit out and return the gearing to home position. It's a 50/50 chance the gears will return or you will need a service tech to pull your coffee unit out and re-sync the gears to the electronics. That's of course if they didn't break.
This blockage is is prevented only by using the cleaning tablets and descaling tablets. Both need to be used as outlined in the instruction manual.
Oct 02, 2009 | Miele CVA615 Espresso Machine
Sep 22, 2009 | Gaggia Titanium Espresso Machine
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Aug 03, 2009 | Saeco Incanto Classic Espresso Machine
Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Aug 06, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Saeco Magic Cappuccino Espresso&Cappuccino Machine Logo
287 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
