Question about Jensen VM9510 Car DVD Player
Dual XDVD700 i grounded the parking brake lockout wire and the screen comes on and plays, but when i turn the key off and then back on and i get that frustating blue screenn PLEASE HELP ME
  • 1 more comment
  • Anonymous May 02, 2008
    I need the switch siquence for the E brake
  • gwest May 20, 2008
    Please Help, I have the xdvd700, I installed it last night. When I installed it I grounded the yellow wire that was suppost to go to the parking breaks. When I first tried it it seemed to work fine, but that was with the truck off,when I cranked it up and used the player it would go off by its self and sometimes come back on by its self. I was reading trying to find soulitions,does anyone have any.
  • Anonymous May 27, 2008
    the parking brake prob what is the bypass code
How to get code for xdvd 700
Posted on May 05, 2008
I've researched many ways of bypassing the brake safety of Dual DVD systems, with the help of others in the "Bypassing parking brake feature" thread. For the ease of all new users, I decided to compile this list of the three easiest and most effective methods.
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes.
WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Posted on May 28, 2008
How 2 insall emergency parking wire on dual xdvd700 in 97 deville
Hello! A toggle switch on the wire with the other side to ground...If you have the switch On when you turn the car on...Wait for Dual to boot-up...Then Off and back On...If it's Off when you turn the car on...On/Off/On...You might try permanently grounding the wire first before installing a switch...
Guru..........Saailer
May 29, 2010 | Car Audio & Video
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
Dual xdvd700
This unit is designed so that it may be operated only when the vehicle is in “Park” and the
parking brake is fully engaged. To this end, this unit includes a parking brake lock-out
feature which prohibits the unit from operating if the vehicle is not in “Park” and/or the
parking brake is not fully engaged. When installing this unit, the installer must connect
the parking brake detect wire (“Yellow-Blue Lead”) to the parking brake mechanism in
order to make the parking brake lock-out feature operable. DO NOT simply ground the
parking brake detect wire to a metal portion of the vehicle. Failure to properly install
the parking brake lock-out feature could lead to driver distraction which could result in
serious injury or death to the driver’s occupants or persons outside the vehicle and/or
property damage.
Once the parking brake lock-out feature is installed, the owner/user must not attempt to
disrupt/neutralize the parking brake lock-out feature by (a) partially engaging the parking
brake and/or (b) purchasing/using any device or unit designed to send necessary brake
signals to the unit. Failure to follow these instructions could lead to driver distraction
which could result in serious injury or death to the driver’s occupants or persons outside
the vehicle and/or property damage.
you could just earth the system straight to the veihicle, which will then dissengage the play in park feature, here is the website for the online manual
http://www.dualav.com/support/manuals/xdvd700.pdf
Mar 16, 2010 | Car Audio & Video
How do i by pass the parking brake no video
Well on the eclipse unit you just ground the wire for the parking brake
Jan 09, 2009 | Dual XDVD8181 Car Video Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
Aug 26, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Parking brake bypass
make sure you ground the e-brake wire (yellow with blue stripe) then turn the power on, insert a dvd, let it play until you hear a sound, then on the remote press: stop, stop, 2, 6, 6, 0, 4, enter.
Mar 21, 2008 | Dual XDVD8181 Car Video Player
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press ENTER
2. DVD METHOD (Permanent)
** Insert a DVD
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Jensen VM9510 Car DVD Player Logo
565 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
