Question about Hotpoint VBXR1070W
Tub shakes back and forth during agitation
Is it normal for a Hotpoint VBXR1070W tub to rotate back and forth (roughly 10 deg.) with each twist of the agitator? With a full load of clothes, this results in a rhythmic thumping noise, and the clothes don't seem to circulate as briskly as they should. I pulled off the front panel to observe the operation, but can't see anything amiss.
  • Maxbert Apr 29, 2008
    To Julianfix: Thanks. Would I access these screws by removing the agitator? Also, it's the whole tub assembly that rotates back and forth, both inner and outer.
  • Anonymous Mar 22, 2014
    problem is with the tub when the drier works it makes heavy noise.the rubber beading looks twisted.till yesterday it was normal .suddenly it happened
  • 975 Answers
It could be the inner tub thats loose , check for a broken screw at the center mast that holds the inner tub. hope this helps.
Posted on Apr 28, 2008
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
New Hotpoint washer purchased Nov.2010.....Problem 1. Fills, agitates and "drains" NO SPINNING this cycle. #2. Rinse fills with ONLY ABOUT 6-7 gallons of water, agitates about 10-15 seconds then...
may have a bad pressure fill switch and thats the reason not filling all the way have you tried on different load sizes... if this is a top load unit need to check the fill hose that goes from side of tub to pressure switch in console make sure has no cracks or kinks in it... what happens is water fills tub and then pressure from tub water goes up clear plastic hose to pressure switch to tell it to advance to next cycle... may be your culprit. and causing other problems... as far as clothes tearing beware hotpoint had a issue with there tubs coming loose the nut that holds down tub will back off causing exess movement and will allow clothes to get under unit... this unit should be still under mfd warranty... call g.e and get a servicer out there to look at it.. at worst you may have to pay a service charge but parts should be covered along with labor.... good luck pleae vote./...
servicer for 18 yrs heating /air / and all major appliances g.e authorized and lg. authorized for 8 years
Jan 03, 2011 | Hotpoint Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Basket spins while agitating causing water to overflow when full load is selected
you could have a bad transmission. usually the motor and transmission turns one way for agitating and the other for the tub to spin.
Sep 17, 2009 | Hotpoint VBXR1070W
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
