Question about Tamron 55-200mm f/4-5.6 Zoom Lens for Select Nikon SLR Cameras
I have a Nikon d3000 and a Tamron AF 55-200mm lens. I cant get the lens to autofocus with my nikon
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Tamron Master
  • 102,366 Answers
The Nikon D3000 does not have a focusing motor built-in, relying on the lens to have a motor. The Tamron AF 55-200mm does not have the necessary motor; it only auto-focuses with Nikon cameras that have the motor in the camera body.
For Nikon lenses, you need lenses designated AF-S. For Tamron, you need lenses designated USD and/or BIM.
That probably wasn't the answer you wanted to see, but there it is.
Posted on Aug 09, 2010
SOURCE:
Is there a solution to make the 70-300 nikkor f/4-5.6g af zoom lens auto focus with the Nikon D3000
Sorry, no. This lens relies on the camera having an autofocus motor, while the D3000 will only autofocus with lenses having their own autofocus motor.
Dec 27, 2013 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Is Quantaray NF AF work with Nikon D3000
Quantaray lenses are available with a variety of mounts. Assuming you get one with a Nikon mount, then yes, it will work with a Nikon camera. However, unless the lens has a focusing motor, it will not autofocus on the D3000. Some Quantaray lenses have such a motor, some do not.
Jul 31, 2011 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Does the nikon nikkor af 70-210mm telephoto lens fit on a nikon d3000?
Yes. The smaller sensor of the D3000 will make it the equivalent of about a 105-315mm lens on a 35mm film or full-frame digital camera. Also, the autofocus will not work with the D3000.
Jul 20, 2011 | Nikon AF 70-210mm f/4-5.6D Zoom-Nikkor...
Wil the Tamron AF 80-210mm 1:4.5-5.6 fit on my Nikon D3000 and if so how does it perform?
Assuming the lens has a Nikon mount, it will fit on the D3000. Tamron makes their lenses with a variety of mounts, so that one with a Canon mount, for example, won't fit onto a Nikon body.
This lens lacks an autofocus motor so you'll have to focus manually. Other than that, it will work fine. It's not the sharpest lens available, but it's also not the most expensive.
Apr 05, 2011 | Tamron 80-210mm f/4.5-5.6 Lens
D3000 Digital Camera with 18-55mm lens: hi,i brought a nikon 3000 , is it compatible with ...
ALL Nikon AFS branded lenses are compatible with the D3000. The AF lenses are usable in manual mode. Sigma, Tokina and Tamron lenses without the built-in motor are manual mode as well.
To be sure, check the manufacturer;s websites.
Hope this helps,
Andrew
May 18, 2010 | Nikon D3000 Digital Camera
The Quantaray 70-300mm lens
Only if you get the version with the built-in autofocus motor. The D3000 lacks a mechanical AF coupling so AF lenses which need to be driven by a motor in the camera body will require manual focussing.
Either way, you're far better manually focussing the Quantaray/Tamron 70-300mm: the AF performance is very slow, very noisy and hunts around a lot to achieve focus.
Although the Quantaray and Tamron versions are identical lenses, if you have to buy this low-quality budget model then go for the Tamron: it's absolutely no better lens quality (and usually the same price), but the manufacturer's warranty from Tamron is much better than Ritz and is internationally valid. If you resell the lens then the Tamron will have some value (not much though) and the Quantaray will be near worthless as it's not so widely known, and has a poor reputation amongst those familiar with the brand.
"Cheap" isn't always the same as "good value"...
Mar 06, 2010 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
Jan 15, 2009 | Tamron AF 28-75mm f/2.8 XR Di Autofocus...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Tamron 55-200mm f/4-5.6 Zoom Lens for Select Nikon SLR Cameras Logo
381 people viewed this question
Top Tamron Cameras Experts
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Ric Donato
Are you a Tamron Camera Expert? Answer questions, earn points and help others
