FixYa.com
Tags:
Transceivers
Generic problem for all Transceivers
Tranciever Troubleshooting
posted by imi6969 on Apr 28, 2008
Hi
would be grateful to know that how I can troubleshoot the following tranciver
Lancast micro Transceiver 4320-12
when I connect the above transceiver to cisco 2500 router(aui port ) , the RX and PWE led are on .Tx lead is flashing every 10 seconds while POL, LINK, RX, COL, AND JAB Leds are off .
and the router is not showing the ethernet interface on the show ip route command (it should show all the directly connected interface as ip address etc are configured correctly. the ethernet (AUI)interface is working becauseI have checked with the other transceiver 4320-11 on which POL and PWR leds are on ,Tx is flashing every 10 seconds while LINK , COL RX are off
Thanks in advance fot your pro suggestion/help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by sunluvinbum, posted on Apr 29, 2008
Are you connecting them via Cat5 or fiber jumpers?
This Problem Also Relates To: HP (28641B) Transceiver HP (28685B) Transceiver HP (C3399A) Transceiver 3Com (3C1206-0) Transceiver 3Com (3cgbic93a) Transceiver 3Com (3CSFP82) Transceiver 3Com (3CSFP92) Transceiver
Can you Help with these Transceivers problems?
D-Link DE 851 (DE-851) Transceiver
solo tengo se?±al en el...
tengo problemas de comunicacion... Answer This...
HP (28683A) Transceiver
transciver
what turnes on the pwr on the... Answer This...
Transceivers
required,mic wiring details for...
ft 290 wiring details for mic. Answer This...
Transceivers
mic wiring details reqyuired...
yeasu ft 290 mic wiring details... Answer This...
Transceivers
ft290
looking for mic wiring... Answer This...
Repair Service
Find Transceiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
