My vcr won't tearn on and its connected to my tv who now can not tearn on and on top of all that in my vcr there is a vhs that I need to return immediatly.
    Brigadier General:
  • 6,966 Answers
Even if the TV is connected to the VCR, chances are that it would only be the signal (RF or Audio/Video) cables and not the power cords. Both not powering on would indicate an electrical problem such as:
1. defective power strip as wall outlet;
2. blown fuse or popped open circuit breaker;
3. a near lightning strike or power outage that has affected the AC section of the 2 devices.
One that you can try is to remove the VCR from its current location and try plugging it elsewhere. If it powers up (and hopefully you can eject the tape that needs to be returned), then you likewise have confirmed the electrical problem,
Alternately, you can manually removed the tape (with the possibility of wrinkling a few areas) by opening the top cover, determining the motor/gear drive that ejects the tape and just basically winging it. Of course your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 28, 2008
Connecting VCR ,cable box, TV
First connect the cable box to TV using HD-cable (if connection available) or component cable (three leads) observing the colors. Connect cable box to VCR with an S-video cable or SCART if you have an S-video out scart. Connect VCR to TV with another S-video cable (round connectors) or with a scart to an S-video in scart connection. If you are in the US, the scart connections don't apply.
Sep 30, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
I have a number of VHS-C tapes from my various video cameras in the early-to-mid 1990s that I'm transferring to DVD via my DVD/VCR combo device. But several of of these tapes that have the suffix...
VHS-C and S VHS-C are two different animals. Super VHS-C will have much better video resolution than standard VHS and uses better videotape. A standard VCR will not play the Super format. You need a S VHS VCR. You would need not only a S VHS VCR but also a S VHS-C adapter. Yes, Not even the adapter is the same as a standard VHS-C adapter cassette.
You can send out your few S VHS-C tapes to a video conversion service. That might be the least expensive way to get them on DVD. Otherwise you could look on E-Bay.com for either a compatible camcorder (S VHS-C) or the S VHS VCR and the S VHS-C adapter.
http://vhs-to-dvd.com is one video conversion service that should be able to get your tapes on DVD for you. You could also look locally for a video service that does conversions to DVD.
Feb 19, 2011 | Televison & Video
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
My py90vg dvd vhs player does not play vhs. The sound is on but there is no picture
If you have the DVD/VCR connected using the component outputs, then you'll need to also connect a composite video wire to your TV from the DVD/VCR. VHS will not play through the component outputs, only the DVD will and they probably both share the same audio output connection so this would explain the DVD being seen and heard while only hearing the VHS.
Feb 01, 2010 | Funai PY90VG DVD Player/VCR
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
How to record from KS 4110 DVD payer to VCR
Connect your DVD player to your VCR ( the out put from the dvd player is connected to the input of the vcr) then connect your vcr to the tv( the output from the vcr is connected to the tv)
Set your tv to what ever channel you connected your vcr to and hit the tv/vcr button on your vcr remote until you get the vcr displayed on the tv.(ensure your vcr is on when doing that)
now when you get your vcr displayed on the tv , turn on your dvd player and set your vcr to what ever channel you got the dvd player connected to(e.g INPUT 1 etc)
you dvd player should now be visable on your tv
simply insert a blank vcr tape and play your dvd and hit record on your vcr
Aug 26, 2007 | Koss KS4110 DVD Player
Televison & Video Logo
Top Televison & Video Experts
