When I turn on my computer everything on my screen is green how do I fix the problem?
  • Louie  Role
    Louie Role May 11, 2010
    Are you using conventional CRT monitor or LCD?
    Brigadier General:
  • 6,966 Answers
Any development(s) with your concern?
Posted on Apr 29, 2008
  • 558 Answers
Most likely problem is a cable from the computer to the monitor it has been damaged replacement is called for if any other monitor works fine
Posted on Apr 28, 2008
The power button green to amber as soon as i switch my computer on and the screen goes blank? how can i fix this problem ?
one or all of your motherboard components may have been unplugged by accident or the video card may have malfunctioned check to make sure everything inside your computer is plugged in if that doesn't work then time to buy a new one
Apr 02, 2011 | Computers & Internet
When i turned on my moms dell laptop, everything was green, i mean everything, what do i do?
This is a hardware defect. To find out which you must connect an external monitor (or a tv) to it and see how the image looks: if the image is still green then the video chip is defective and in this case you will have to replace the motherboard - very complicated and expensive, you'll be better off just replacing the laptop; if the image is normal then the connection cable between the motherboard and the screen is broken - to fix that you will need to dismantle the lid of the laptop. This is a job for a repair shop and it will cost you around $100.
Nov 16, 2010 | Computers & Internet
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
My flatscreen monitor has went a bright green colour, you can still see a picture (part from everything is green) I have tryed puttin another monitor connected 2 the computer and it works fine, so i no its...
you should check your monitor display cable first and second may be back pcb socket and ic is loose so it leave color combination and your screen will be green.you should repaire your monitor very soon otherwise it will be more damage.
Dec 03, 2008 | Computers & Internet
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Pop goes the weasel
I agree. The monitor probably blew a capacitor.
Time for a nice new LCD monitor.
Dec 14, 2007 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
