Wireless on Aspire 5310 running really slow despite great signal - and internet is working fine on other computers in the house.
  • 558 Answers
I would start be looking at the connection setting and see if it is set to 10 mips or 1/2 duplex
Posted on Apr 28, 2008
Why is my computer so slow to connect to internet web sites
I would try to connect using a wired connection instead of a wireless connection to see if the speed increases. Also go to Speakeasy Speed Test and run a test to see what speed your internet is really running at.
Sep 24, 2014 | Acer Aspire Desktop Computer - Intel Core...
Advent 9315 wifi
How are you connecting to the internet?
1. Wireless
2. Wired
This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it.
A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.)
How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
Mar 31, 2014 | Zyxel Computers & Internet
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
Why will my Acer Aspire 5552 running W7 only connect to the internet when it's near the router? When elsewhere in the house, it shows 2 bars on the signal strength, but will not connect to the rou
That means you have a crummy internal wireless card. Your best bet would be to purchase a USB wireless card and your problem will be solved.
Mar 21, 2012 | Computers & Internet
Nothing on the internet works, it's really slo and constantly dissconects, everyone else in my houses computer are great wit the internet but mine is horrible.
are you connecting through wireless? how strong is your signal, if its weak then you will have these problems, I would suggest a wireless extender to give you more coverage, also check your power settings to make sure that your wireless isn't set to power-save. Also, clear your browser history and run spyware software, I always use superantispyware but there are several to choose from. Lastly make sure you defrag your machine at least once a month.
Hope this helps.
May 09, 2011 | Computers & Internet
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Desktop has very poor/slow connection through wireless router
This sounds like a spyware/virus problem. Try running the computer in safe mode(With networking) and see if it's any faster. You should also run your Anti-spyware,AV apps to check for problems.
Sep 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
