Question about InFocus X1 Multimedia Projector
Blurring Heyya there, when i switched on the projector, to the left hand side of the illuminated screen is a yellow blurring...where its supposed to be a clean definate edge??
  • 14 Answers
Check if it is not the same problem as http://www.fixya.com/support/t401456-infocus_x3_video_problem
Posted on Sep 14, 2008
    Genius:
  • 1,673 Answers
This can be a fault with the lens or the imager. It is hard to know without doing some tests, and trying a new lens and a new imager.
Jerry G.
Posted on Apr 28, 2008
Yellow blur on screen
Blue LCD (from RGB ones) is either dirty or burnt. Google how to DIY exchange it.
Dec 06, 2010 | Philips bSure SV1 Multimedia Projector
I have an Epson EMP TW10. I have replaced the lamp but it will not illuminate. The temperature warning light flashes red permanently after switch on.
Hi
Can you check the filter for the projector, looks like a screen underneath or on sides, open and clean it up.
Hope this helps
Mar 26, 2010 | Epson EMP-TW10H Multimedia Projector
The left side of the screen is blueish?
The blue or yellow haze problem in this projector is because of two factors. 1) Dust buildup inside the optics and 2) Fading colour filters used in the internal optical process.
Inside the projector the white light from the lamp is split into three distinct colours of red, green and blue. Each colour illuminates their own monochrome LCD. Those LCDs are mounted on a prism that combines the separate images and displays the result you see via the lens.
The optical process to split the light up inside the projector is fairly complex and involves many light filters and mirrors to direct the light to the appropriate lcds. Those filters and lenses accumulate dust and also fade over time due to heat and other environmental factors.
I know that sharp sells replacement filters at $100 a piece. I do not know if Hitachi sells replacements.
To remove the dust and change filters you have to take apart the projector in a fairly complex way. I do not suggest that the average user do this. Good luck!
Mar 18, 2009 | Hitachi CP-X445 LCD Projector
Blurred side of projector
This is caused by misaligned lens and/or display panel (LCD or DLP). Recommend a trained tech to perform alignment.
Mar 08, 2009 | HP Digital Projector Vp6110 Multimedia...
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
Display fault
either the light filter before the blue lcd is fried or the 2nd fly-eye lens is. take the lamp out and shine a flashlight through the glass in the projector. if you see blackened burn marks on the other side of the glass, the fly-eye lens is burnt and needs replacing (but is currently out of stock). if not, it's the lcd light filter (which is in stock).
Sep 04, 2008 | Sharp Notevision XG-C50X Multimedia...
Heyya got a infocus x1a ..im running it from vista...but there is no recognition--the projector is searching ..but what is it searching for..also there is a yellow blurring to the left of the projected...
the light tunnel is collapsing. that's causing the yellow bluring. as for the recognition, make sure that the resolution matches what the projector can handle (max 1024x768).
Apr 30, 2008 | InFocus X1 Multimedia Projector
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Dvd/vcr combo hookup
your audio video cable is probably plug into the wrong places the way that it goes is this with the dvd player on the right hand side you will see video the yellow cord is supposed to be up at the top where it is color coded at the bottom on the left hand side you will see audio for the left it is white the right hand side it is red for the television it is audio for this you put the red, and white cable at the bottom on the left hand side for the video it is just the yellow cable it is supposed to have three cables in a row at the bottom of the television
Aug 08, 2007 | Symphonic WF803 DVD Player/VCR
InFocus X1 Multimedia Projector Logo
181 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
