Question about HP DeskJet 940c InkJet Printer
Printer will not print
The middle light on far righthand of printer is on and printer will not print. I have no manuel to diagnoss the problem .
  • 12wert12 Oct 08, 2008
    my printer wont print anything and at the bottom right hand corner a little picture of a printer comes up and when i click on it the name of the document that i was trying to print appears but it still doesnt print
Paper is stuck in printer.I cannot free the paper which is stuck in the printer & I will need an expert to solve the problem.
Posted on Sep 08, 2008
When I print an email I get the righthand side covered by adverts on my acer 5735z
you'll need to file the actual print "button" if you print "screen" this will happen all the time
Jul 11, 2014 | HP LaserJet 4350 Printer
I turn on the Pixma mp130. Print head slams to the right side. Display says "CHECK INK TANK" and alarm light blinks. I open the lid. Print head remains on far right. I depress teh closed lid...
It sound like the indicator strip has moved or is damaged.
  1. turn the printer on,
  2. get the cartridges to the middle,
  3. pull the power out.
  4. remove the head from the track and move it manually to its correct position.
  5. Be careful not to damage the plastic indicator strip that runs behind the print head. this strip is used to reference the heads position in the printer.
I hope this Helps Regards GM
Apr 12, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Faded Stripe in the middle of the page
You need to clean the drum When I was working for the City There was the same problem with the Laser printers. Check the Manuel and see if there is a page on cleaning the print drum on your machine. Also you may try Talking the cartage out cleaning there as well It seems you are picking this up form somewhere after the print My Guess would be the print drum? You may also have to replace the drum as well. I am guessing that this is a laser printer? if not then there are other solutions.
Jun 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
I just changed my ink cartridges. The test page will print, but the computer page I'm trying to print...won't. In the bottem righthand corner the printer icon keeps blinking along with a left facing...
hi,
First of all would like to help you so that you can cancel your print job.
On the bottom righthand corner where the prinetr icon blinks simply right-click it and select "cancel," after which the print job status commences to display "deleting..."
So you shoud not be worried about loosing your receipt as you can print it again.
Also
  1. I would like you to unplug the USB wire connected from your computer, turning the device off and then connecting everything from scratch. You can also restart the computer.
  2. Then once the computer is on please click on START and go to RUN and type in services.msc and then on the right side of the page find print spool and right click, then choose restart.
And then try for fresh prints.
Please let me know if the above information helps.
Feb 09, 2010 | Office Equipment & Supplies
I have filled the paper tray with paper and will not print
Try to flip down the back cover and lower the flap that covers the rollers. On the inside of that flap, right in the middle of it, you will see a small, one inch long lever that helps keep the paper up against the roller. This lever was moved to the left a bit to far, so I nudged it to the right. As soon as you do this, the light should stop blinking and the printer should work.
Jan 19, 2010 | Brother HL-2040 Laser Printer
White line across photo
clean ur printer head. and check that if any air ur ink box
Jul 21, 2009 | Dell 540 Photo Thermal Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
OKI Margins
Are you using compatible ribbons which maybe to tight try geniun OKI ribboms.
Hope this helps,
Dezzi
Apr 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
HP DeskJet 940c InkJet Printer Logo
Seeker5211
Seeker5211
