I have an old pair of Altec Lansing speakers that I love. Unfortunately, the wire that connects the speaker to the powered speaker has cut in half. Is there any way I can get a new wire or get this speaker fixed?
    Genius:
  • 3,587 Answers
Can you resolder that wire?
Posted on Apr 28, 2008
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
I need to open the speaker cases to troubleshoot why I have massive 60 Hz cycle hum, static and loss of signal to the amplified unit of the pair ( the one without controls). How can I safely open with...
Please don't post contact details to this open Forum. We get 7 million questions a year and millions of more views. At least some percentage would love to phone you are 3:00am for a chat or have a thought to scam you.
Regarding your question. There is no point in getting INSIDE the speaker because the problem will not be inside it.
I got rid or my Altec Lansing 2+1 Computer speakers for the same reason. There was a hiss even with the power off. The only way to stop it was to pull the plug. They are not well made. Check the plug on the speakers and move the wires from any other that are carrying power. Try disconnecting them altogether and set them up on a table. Connect the computer to a cellphone and see if you still have the same problem.
If you like GOOD quality sound, I have a pair of these. They are amazing. You can find them at a better price.
Bowers Wilkins MM 1 Review Trusted Reviews
Oct 03, 2017 | Altec Lansing VS-2420 Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
I have a pair speaker altec lansing model acs300.1 i need the power supply transformer
Buy some broken ones off eBay, throw them in the bin and just use the power supply :D
Dec 15, 2009 | Altec Lansing Multimedia Computer Speakers
I have Altec Lansing 221, good sounding speakers but the connection cable from the speaker to computer shorts out. Any idea for a replacement cable? Thanks
I would disconnect the power before doing anything! then go to radio shack and buy a cable with the correct plug on it. Then i would cut off as much as possible of the old cable to the speaker, but leave enough room for splicing effectively. Then i would cut open the radio-shack cable and connect the wires of that cable to the remaining wires of the old cable still attached to the speaker. red is left, black is right, and the un-cased wire is negative. Try to figure out what is what on your old wire so that you can splice everything together accordingly. I hope this is not too confusing!! Good Luck!!
Jun 11, 2009 | Altec Lansing 221 Computer Speakers
I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
May 02, 2009 | Altec Lansing AVS 300 Computer Speakers
Altec Lansing speaker - model ada 745
I am guessing you mean the cord that goes into the PC, I don't know how "Broke"it is, but you should be able to cut the old end off and replace it, if you buy an inexpensive speaker extension cable, you can use that for the new end, or try radioshack, they may have replacements that just need to be wired, usually a black and red wire is all, just tape it up good to avoid shorts
Apr 30, 2009 | Altec Lansing ADA 890 Computer Speakers
No sound thru Altec Lansing speakers on computer
maybe the plugs going into the back of computer are unhappy..can you do a continuity check on the prime and ground of those?
Mar 15, 2008 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
