I have 6 Maxtor drives, from 1 30 gig, i 40 gig, 120 gig, and 3 80 gigs. Recently I have had failures on 3 of these drives. One minute they are fully functional and the next day they won;t boot and the error message I receive is "There is no Maxtor drive in your system.: I have tried running the drive to 0, using you utility Max Blast #3. but to no avail. Do you have any suggestions? Or do I now have 3 cut door stops? Right up front I feel they are most likely out of warranty, but a response would be nice as I will probably continue to purchase Maxtor products. Thank you, William Porter
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    are these external or internal drives?
  • 558 Answers
The hard drives will have a date stamped on them if they are within their three year warranty period you should contact the hd manufacturer and see if they will refurbish it for you .
Posted on Apr 28, 2008
750gb
3.5drives require 12vdc at no less than 2 amp recomended 12vdc 3amp it is always best to provide more amp for hard drive keep the voltage correct 12vdc
asme adaptors work out to 4 gig drives all my Western digital drive have same power adaptor no matter the Gig size .
May 05, 2014 | Maxtor Hard Drive
Win98 does not recognize the Maxtor OneTouch III 500Gig.
First I will want you to know that support for win98 has long reached end of life. I don't think that win98 support mass storage unit of that capacity. I will suggest you opgrade your os to winXP
Dec 28, 2009 | Computers & Internet
80 gig maxtor not reconized in computer bios cmos
check the cable & more better way use duel usb cable which occupy 2 usb & i Normal Hdd connector
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
just need to set the jumper so this will work as the slave
Apr 18, 2009 | Maxtor Hard Drive
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
80 gig maxtor
change hard board or
change your cables (date & power)
Oct 27, 2008 | Maxtor Hard Drive
Memory loss
It seems to me that when the drive was partitioned, the whole thing was not partitioned. If using Windows XP you can go under the Control Panel, Administrative Tools, Computer Management and then Disk Management. You should be able to see the drive and if any unpartitioned space is available.
Sep 09, 2008 | Maxtor Hard Drive
Bios won't reconise 160 gig maxtor harddrive
You could try a BIOS update to increase the size of the Drive the BIOS is able to see.
The second last one indicates that drive sizes are supported over 65GB. It may still not be able to see the 160GB HDD, but this is your only option with this Board. You could always upgrade the Motherboard to support larger drives.
Good Luck.
Apr 24, 2008 | Maxtor HARDDRIVES Hard Drive
Moving files
just go to All programs<Accessories<System Tools<Backup. and choose the option you want.Once you have choosen what all you want to backup than you can choose the option for the place where you want to back it up.
Hope that works!
Dec 27, 2007 | Computers & Internet
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
