Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Can't Remove Front Panel
I also have the KP-57WV600. I tried removing the front panel, but it simply won't budge. I removed the back panel and saw what was keeping the front panel in place, and still couldn't get it. Have any tips I could use?
  • 18 Answers
From comments at this blog on how to fix lines across Sony Projection TV:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Comment1:
To remove the cover on the KP57WV600, remove the 5 screws behind each of the speakers. Then pull out the bottom center of the grey panel. It is held in by 4 snap type pins. The cover hinges at the top. Rotate up and be careful not to pull out the wires connected to the front panel. Then proceed as directed here.
Comment2: For those with KP-xxWVxxx TV series you need to remove 5 side screws, just behind the faceplate covering the speakers, next - pull out the 4 round-shaped clips on the botton of the faceplate and last - push-in the top part of the faceplate & pull down at the same time to dislodge the 4 large flat-shaped clips on top.
Comment3: My model required me to removee the 5 screws on the rear facing side panels (LH and RH lower facing aft) then with moderate force grab the lowest edge of the gray front face panel and pull out towards your self. Gently supporting the weight of the panel since there are slotted alignment pins at the top of this panel.
Hope this helps! :)
Posted on Jun 05, 2008
    Problem Solver:
  • 11 Answers
Sorry, haven't checked this in awhile. Remove all screws from lower right and left side. Grab the entire front lower piece, pull down and towards yourself. It takes a little more pressure than you would guess, because there are four large plastic clasps that have to come out of their slots to release the panel. Once loose, don't pull it away from the set more than a foot, because it will be attached by cables.
Posted on Dec 09, 2008
You didn't try hard enuff ,, dont be shy it wont break , but the clasps must break it's seal .JUST PULL IT OFF BUT NOT TO FAR AS TO PULL THE WIRING HARNESS OFF
Posted on May 12, 2008
LG Tromm front load washing machine WM2688HNM, does lid on this washer remove differently from other LGs? Trying but won't budge HELP SOS!! How do I remove lid to get to inner works of this machine?
You need to remove the front panel there’s 2 screws behind that panel once you remove those screws the top from the front push it towards the back and slide it up at the same time
Nov 18, 2017 | LG Washing Machines
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
Oct 08, 2011 | Sony KP-57WV600 57" Rear Projection...
I have a paper jam in my MFC -7420. I removed a sheet from the back but there is more stuck in the front. The message says to open front cover and remove drum. I have opened the front cover but...
Don't try to remove the drum by itself while it's still in the machine,
just simply remove the drum and toner cartridge together.
There is no lock you should just be able to pull the cartridge out.
Jun 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
You see red and blue lines curved across the screen when there is a blank screen
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
How did I correct blue and red lines curved across a blank screen of my KP-57WV600 SONY Projection TV?
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue and red CRT. I don't remember if the focus block is in the front or in the back of the tv on this model. Most projections have them in the front.
You could check the back access panel and look for a black box with six knobs as descibed in step 3 below. This is what you are looking for.
follow the steps below if it is located in the front:
Red lines on screen
On the front down bottom there is a fake button hole cap pull it out and remove screw one on each side and you might have to remove back to undo 2 more screws inside TV. The screen/focus Block is behind it 3 controls on top 3 on bottom R-G-B Check Video IC on CRT board of Red Tube/ First try adjusting Red screen drive control .Let me know if need any help.
Jan 01, 2009 | Sony KP-57WV600 57" Rear Projection...
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
What's wrong with TV?
how many times does it flash?
i suspect a bad red tube
sony has a recall on the tubes
http://esupport.sony.com/perl/news-item.pl?news_id=24
Dec 29, 2007 | Sony KP-57WV600 57" Rear Projection...
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
SONY KP-57WV600 - Small green lines across the screen
According to several sites, the problem is with the convergence via the voltage on the color ray gun tubes that get out of adjustment. They are also known as retrace lines
Sony wanted between $150-$300 to diagnose and fix -- instead I was able to complete this repair in less than 15 minutes!
Since I had been through the routine once more and I was sure others are running into this issue,
1. All you need to complete this guide is one flat-head screwdriver and one Phillips screwdriver as well as a delicate touch.
2. Front shot of the television. Their are two screw holes on the front of the unit near the edge of each side right next to the speaker grille.
3. Close up shot of the screw hold. It is covered by a plastic cover that has two tabs holding it in. Carefully pry them out with your flat head screwdriver. Do not apply too much pressure or you can break the tabs off. Once the covers are removed, unscrew the two screws with a Philips screwdriver.
4. To remove the cover, pull from the bottom of the front case and rotate towards you. Once you rotate it out, the top will disconnect and come loose. Do not pull it off, as there are cords attached. (see picture) Loosen the cables attached with the twist ties and set the front cover to the left side.
5. With the speaker grille and cover removed, you now need to remove the wood panel to expose the inner electronics on your Sony HD TV. To do this, remove the four Philips head screws from the panel. Then, pulling from the right, rotate the panel off and the electronics will be exposed.
6. This is a picture of the inner electronics of your Sony Rear-Projection High Definition television. The little black box towards the front of the unit is where we will concentrate our time as it is the control for the voltage & convergence adjustment.
7. When focused in on the controls, you want to concentrate on the bottom row for the voltage / ray gun projection adjustment. The colors are labeled below and from left to right are blue, green, and red. Choose the one that needs to be adjusted and turn ever so slightly with your Philips screwdriver to remove the lines. In my case, the red just needed to be turned 1/8 of a rotation to be back in adjustment. Do not turn to quickly or abruptly or you could possibly damage your TV by varying the voltage too quickly.
7_red_blue_green_voltage_band_adjustment.jpgI hope this guide worked for you?
Dec 17, 2006 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
604 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
