Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore Cannister Vacuum Model 26312
Vacuum is not sucking. It is just over a year old.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
Kenmore cannister vacuum model 116.2411290 has begun exhausting a 'burned' smell. Suspect bad blower bearing. How to access?(Can't find manual online.)
Hi,how are you so sure the problem is from the blower bearing and not the belt,well to know if the problem is from the blower bearing or the belt you have to know how to access your vacuum first,so from all angle you need the manual You can download the manual of your kenmore cannister vacuum from this website;www.manualsonline.com.I found it there Thanks and take care
Apr 01, 2010 | Kenmore Vacuums
Kenmore 34723 Grab-N-Go Upright cannot re-attach dust cannister
make sure the top of the dust cup is properly installed and for kenmore parts go to www.searspartsdirect.com and inter the modle #
May 22, 2009 | Kenmore 34723 Grab-N-Go Upright Vacuum
Seems to have poor suction
try this take some duct tape place it where the cannister and the seal meets then vacuum. if that not it you my have a clog.
May 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
VACUUM WON'T SHUT OFF
Most likely the pcb in the cannister is bad, part # KC86WBZRZ000
Sep 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
490 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
