Question about Technics SC-DV290 System
Speaker cut-out I have a Sony receiver and the speakers are at least 20 yrs old. The speakers go in and out, ie., one on, then two on, quite frequently. I've messed with the wires, etc. no results. When I turn up the volume, and then down, the speakers are good for a short time. Help!
    Scholar:
  • 186 Answers
Most likely there is an Ohm Resistance difference between the speakers and what the receiver support. Look at the back of the speakers to see what they are, and look at the back of the receiver and see what it supports. When a receiver is powering a speaker of different ohms, it will do exactly as you described because of Amp confusion. If you really want to use these speakers, there is probably something you can buy at radio shack to put in between the receiver and speakers to lower ohms if speakers are too high rated.
Posted on Apr 28, 2008
Yamaha RX-V793 receiver shuts down when I turn up volume. Checked the speaker wires and they seem okay. I then hooked it up to an older DVD player I had and it works fine. Don't know if it's 5.1 bu
My first thought would be that when you moved the receiver to connect another DVD, the problem quit since the speaker wires moved. The best way to test would be to re connect the original unit the same way as the new unit and test again. If it still cuts out, disconnect the speaker wires and re test. if it still cuts out, try the new player and test again. if it does not cut out, there may be a problem with the old units audio output. Generally if its a problem with the receiver it would not matter what source you are using, even the tuner on the receiver, if there was a short in the receiver it would cut out. Let me know what your results are and I will help more if needed. Best of luck!
Nov 24, 2011 | Yamaha Audio Players & Recorders
I have bose speakers connected to a sony receiver and I want to chance the sony receiver to a bose receiver without changing the wires on the speakers. The sony receiver was old and has stopped working. ...
Hi.
Even though you may need to put new plugs on the ends of the wire, you can still use the wires without having to go out and by new.
Places like Radio Shack, Fry's, Ovation, BestBuy, and CompUSA all carry wire plugs that you can install yourself rather easily on the old wires to make them work with the Bose receiver.
Putting plugs on the ends of the wires is really a simple thing to do.
Just follow the instruction that comes on the pack, and you should be fine.
I don't blame you for wanting to utilize the old wire, it can get expensive to replace speaker wires.
The plugs are a cheap way of saving wire, and saves you quite a good deal of money as well.
I hope this helps you out, and good luck !
Jun 07, 2011 | Bose Cinemate Digital Home Theater System...
My receiver is clicking on for a split-second then shutting down when I hit the power button...anyone know what that could be? thanks (it is about 11 yrs old)
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
May 29, 2010 | Yamaha HTR-5140 Receiver
Problem With Onkyo Receiver Protected Mode. Disconnected speakers and plugged to different outlet and still shut's off with protected mode on. It's 12 yrs old.
Receiver say's "Protect" or turns on then off posted on Dec 13, 2009
MessageRate.ThreadID = 3632423; MessageRate.ProductID = 0; c81ea4d.jpg smarthome2
Rank: Guru
Rating: 88%, 432 votes
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers2_bing.gif one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Feb 28, 2010 | Onkyo TX-SV444 Receiver
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Jul 15, 2009 | Wave Audio CS801 Speaker
Everytime I put the volume up it cuts off saying protect...! How do i turn off the protect to allow sound to increase.?
I would check all speaker connections and speakers, check the speakers with an ohm meter and compare the resistance with all matching speakers and on the nameplate if there is one, my amp did that last year and i found a burnt coil in one speaker ( center channel) hooked my old one back up and solved the problem for me. GOOD LUCK
Feb 01, 2009 | Sony STR-DE597 Receiver
Friend gave me a jbl surround system to go with my 52" sony hd tv. It has four speakers. three sat 20 and one bass 20. going to a rca stva 3970 receiver. didn't have instructions to go with it.
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | JBL 5.1-Channel Home Theater Speaker...
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
Technics SC-DV290 System Logo
63 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
