Question about JVC Audio Players & Recorders
RX- ES1 Home Cinema control centre switches into standby mode
5 Suggested Answers
SirHanz
  • 145 Answers
SOURCE: jvc rx-e100rsl home cinema control center
unless there are some other connectors that may be used, i would think that the issue would be resolvable thru the system settings menu, there may be a speaker arrangement setting somewhere in the menus. The Sub is a .1 setting like 5.1 or 7.1, perhaps even 2.1 where the beginning number is the speaker channels and .1 is the sub. I would think with the sub being on a mono channel it woul/should work with any setting. If there is any more info you could supply I will further research this issue and try to help you get the sub working.
Posted on Jan 27, 2008
SOURCE: I have a Samsung HT-z510
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Posted on Mar 01, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: my samsung home cinema system switches off after a
Check your speaker wires make sure they are not touching each other. Other than that you probably have a shorted power amp inside.
Posted on Jun 27, 2009
  • 302 Answers
SOURCE: sound from home cinema centre
Have you checked the setting on the sound menu. if that doesn't work you might have to replace it. you can get parts for TV's at www.interliquidparts.com
Posted on Jun 02, 2011
My Yamaha RX-673 not powering on. On standby mode
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired not problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
Panasonic SC-BTT775 home cinema centre speaker has stopped working it was fine yesterday but I disconnected the wires to clean it when I run the speaker test I can get sound through it but that's it?
Some units have the ability to switch off the centre channel in different sound modes. It sounds like you have somehow switched it off. A careful read of the manual should get you back with sound.
Sep 07, 2015 | Panasonic Audio Players & Recorders
How to reset reciever
If you can't resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults,
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. "Clear"
will appear on the display and the AV receiver will
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Mar 17, 2013 | Onkyo TX-SR606 Receiver
Can the epson projector 8700ub be used in Australia with our power suppy being 230 volts? Thanks. Mr Tay thengtay@hotmail.com
Rated frequency 50/60 Hz AC Power supply 100 to 120 VAC:
3.1 A (Home Cinema 8350) 3.3 A (Home Cinema 8700 UB) 200 to 240 VAC:
1.3 A (Home Cinema 8350) 1.5 A (Home Cinema 8700 UB) Power consumption 100 to 120 VAC: Operating: 272 W (Home Cinema 8350) 297 W (Home Cinema 8700 UB) Standby: 0.2 W 220 to 240 VAC:
download the manual for this model
Techbelkin
thanks for rate me.
Jan 08, 2011 | Epson Power Supply 110/200 VAC Switchable...
When I switched to hdmi2 today the display shows "PCM" for a few seconds, then displays the Dolby-sign and "PLII Movie". It used to show "Standard". What have I done wrong and what sould I do to fix it??
You have changed the Cinema mode to use some Dolby effects. Press the "Straight" button on the remote, it should turn off those effects (pressing it more times will cycle between some other options, but you need it to display "Straight").
Aug 28, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Digital projector not working
check if standby led on projector is glowig red, if yes pannel keys may be in off mode, try to power on with remote control.if standby led does not glow, check power cable and its connections and safety fuse inside projector.
Aug 14, 2010 | Sony VPL-ES1 Multimedia Projector
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
486 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
