Toshiba 3301 desktop copier
I know a jam should be easy to find on such a small and simple deskltop copier but having no success
every time i hit the copy button the slide top will slide all the way to the left and then stop shortly after it reverses itself and starts heading right. The jam light comes on and of course i have to open it up to reset so i can activate copy again. I do nothing to clean any jam as i just dont see any issue but the jam light goes out when i open it and close it back up
I have started a copy with the slide top all the way to the right, all the way to the left and from the middle and it stops thinking perhaps it had to cycle thru and it jams and stops at the same place every time--just dont see any paper stuck up in there
anythoughts since i just dont see any paper caught up in there
thanks all for any help
  • yabadabadoo Apr 28, 2008
    heres a update--
    it will complete the copy cycle on auto feed without jamming----its jamming on feed from tray
    copy came out about 75 % black with just a little of the image showing----------i put it on light and its still virtually all black????????
    Problem Solver:
  • 16 Answers
This problem can never be solve on Net, I have had this problem many times with small canon copier, it is a mechanical error that need to be corrected at the point of clutching to return back.
this us to occur when the Copier has worked for long, that is to say the the copier becomes weak. so ...
Posted on May 08, 2008
I have a Toshiba estudio162 and its saying clear paper jam. I opened the tray, removed the crumbled paper and closed it.Its still saying Clear Paper Jam. How do i make the red light stop flashing?
The sensor acturator that the paper hits might be broken or out of place so the copier thinks there is paper there when there is not or there might be a small piece of paper that stuck in there holding the sensor acturator up.
Nov 17, 2015 | Toshiba Office Equipment & Supplies
Copier insists there is a paper jam when there isn't.
ok have dealt with this a ton at my old job and found that if you take out all trays toner packs anything that is made to be removed then do a quick check for any paper jams or even small bits of paper that may be stuck and remove it all then put everything back together it usually fixes the issue. If that does not work then a reset of the machine may be in order simple turn power off and back on. you can hold the power button in til it shuts off or simple unplug it leave it off for about 15 seconds then turn on and check again if that doesnt help i dont know .
May 12, 2015 | Canon ImageRunner 3025 Black and White...
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
I have toshiba studio 161 \r\nproblem is there he errer is paper jam please solve this problem
check all the paper path maybe there is a small piece of paper remain inside or the actuator of fusing sensor is broken just check it
Nov 22, 2010 | Toshiba e-Studio 161 Copier Copier
Each time the printer goes to print the paper
Either you have a problem with the fuser itself, such as a drive gear problem where the fuser is not turning or the is toner buildup on the fuser entrance plate. The toner buildup is a common problem so I would check that first. The fuser is easy to remove and you just beed to flip it over and look closely at the plates that "guide" the paper into the fuser rollers. Look for any small globs of melted toner that the paper is hitting when it tries to enter the fuser. If you let it cool down first then the toner can usually be chipped away and scraped clean. Then just reinstall.
Good Luck.
Mar 04, 2010 | HP LaserJet 4650n Printer
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Paper Jam Error but no paper is jammed
depnding on which way you removed original jam you could have left a very small peice behind at a sensor arm, inspect very carfully at and before where the jam was
Mar 17, 2009 | Canon D320 imageCLASS Digital Copier
Printer Networking
Make sure both devices are connected to the same network, the printer is on, and the desktop can successfully print to it.
  1. On the desktop, go into your Printers and Faxes section from the Start Menu or Control Panel. Right-click on your printer and select Sharing. It may ask you if you want to learn more but you can hit "Just enable sharing" and then hit the radio button to "Share this printer." You can pick a name for the printer if you wish, or just hit OK.
  2. On the laptop you'll need to connect to the desktop through Windows Networking. If you know the name of the computer you can just type "\\COMPUTERNAME" without quotes and put the computer's name after the two back-slashes. If you don't know the name you can go through the Networking and Sharing center to view your network.
  3. Once you are connected to your desktop you should see any folders or printers that have been shared. If your printer is the only thing you have shared then that's the only entry you should see. If you double click on the printer it should ask you if you want to connect to the printer, which should take some time. Once you see the Printer queue window pop up you have successfully connected to your router!
At this point the network printer will have been added to your laptop's list of available printers. When you go to print something just hit the drop-down box to select the printer connected to your desktop computer, and Windows will take care of the rest. Happy printing!
May 13, 2008 | Office Equipment & Supplies
E-studio 520 copier Jamming
Where is it jamming at and what code is it giving.  Press the clear and -8- buttons at the same time to see code on screen.
Oct 19, 2007 | Toshiba COPIERS E-STUDIO 520 Copier
55 people viewed this question
jasbo
jasbo
