Question about Canon S520 InkJet Photo Printer
AC Adapter # K30170
Gentlemen:
My wife tripped on the printer electrical cord, and the printer fell to the floor. The cord plugs into an AC Adapter/module (K 30170) witch can be remove from the printer's back by pressing 2 tabs. After removing it, 4 or 5 color wires that go into the printer are exposed.
I did some tests with my VOM and no voltage reaches the printer.
Can you find this part from an old/broken printer?
AAV
  • 32 Answers
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
The printer is plugged in but does not turn on. The green light on the AC adaptor is on. I have tried a friend's AC adaptor and it did not work either.
I think it would be wrong to suspect a problem with the adapter wire if the same problem occurs with two adapters. Do both adapters work with your friends printer? If so one would suspect that the plug port on your printer is defective.
This is the advice from the manual:
Power button is not lit
1 Disconnect the power supply cord from the wall outlet, and then from the printer.
2 Plug the cord all the way into the power supply port on the printer. make sure it is well seated
3 Plug the cord into an electrical outlet that other electrical devices have been using.
4 If the Power button light is not on, press Power.
If this does not correct the problem and it is a new purchase I would consider returning it to the vendor. Otherwise you may need to have a technician Tto investigate and confirn that power is reaching the printerre and the problem lis elesewhere with a switch or posisbly you need to replace the power connector port on the printer.
Dec 11, 2010 | Lexmark X8350 All-In-One InkJet Printer
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
Hello my name is greg and we were having trouble with our electricity and we shut off the wrong sircut breaker and now our WII doesnt turn on but we are unsure if it is the power cord
The best way is checking the power cord with voltmeter or some unit like charger for mobile phone (plug it and look the phone charging).If the power cord is OK plug the Wii AC adapter.If Wii not turn on check the AC adapter with voltmeter.If working the problem is in your Wii console and it need repairing.If AC adapter not work just buy new.
Nov 09, 2009 | Nintendo Wii Console
Power Supply cord from ac adapter to wall plug needed
Any electronics store should have one, they are all the same. try radioshack
Jun 19, 2009 | Western Digital My Book Essential Edition...
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Canon S520 InkJet Photo Printer Logo
60 people viewed this question
old marine
old marine
