Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Wireless connection problem - XBox Live
I can't seem to get the signal to the XBox from the wireless
  • Cricket234 Apr 30, 2008
    I can't get this adapter to connect to my network it picks it up but won't connect.
    Scholar:
  • 70 Answers
Make sure that the wireless settings on your router is the same as the settings on your XBOX also the Xbox should be able to work when wired to the modem to make sure that ports are not blocked. You can give that a consideration too.
Hope this helps, if you have other questions, message me then I'll answer it as soon as I can.
Posted on May 05, 2008
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
I have a wireless internet connector for my xbox and i cant seem to get it to connect to xbox live. i can get it to read that there is a connection to my computer and the signal is stong but i it wont...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Dec 23, 2010 | Belkin N150 Enhanced Wireless Router...
I can not seem to get onto the internet with my Wireless connector for the xbox live it is trying to get a signal but is not connecting can you help. The connecter is flashing at Green but just does not...
make sure that you run the dvd it came with, that is the most important, then go into your setting on the xbox and pick your router out of the list, the green light should stop flashing when it picks up your router, especially if you have a password on your router, you will need to enter that in the settings screen
Feb 28, 2010 | Microsoft Xbox 360 Wireless Controller
I keep getting dropped from xbox live with my wireless N router. Is this common? Is there a common setting I forgot to turn on?
Did you try moving the wireless adapter to a different location, possibly the front of the xbox to get a better signal. Make sure nothing is interfering with signal such as objects in the way or other obstructions to line of sight between the wireless router and the xbox. Try running xbox live on a wired connection to see if you have the same problems. If still have a problem then it is a ISP or xbox live issue and not your wireless adapater.
Jan 05, 2010 | Microsoft Wireless Network Adapter Xbox...
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Testerday we connected to xbox live but today we cant connect why
Are you wireless or are you wired. If you are wireless, sometimes phone signals interrupt the wireless signals if you have a wireless phone nearby. Some wireless phones are very messy with the signals they send.
Jan 01, 2010 | Microsoft Xbox Console
I can't connect to xbox live , it tells me to test my connection , its going fine , halfway to through the xbox live bar then an update pops up , if i say i dont want it , it signs me out of xbox live
have you tested the Internet connection? what are you using wireless or wired? this isue comes up sometimes when you use wireless and it looses signal... this can happen if the xbox is too far from the wireless router OR there is interfearence ebtween the 2 devices (microwave, wireless phones, etc.)
Apr 13, 2009 | Computers & Internet
Boost signal to allow xbox live
1 buy and cantenna and a hawking hwug1 (from hawking website). install hawking on computer (usb wireless device) and then run the network wizard to make the connection a proxy server. run a lan cable from the computer to the xbox, and enable the wireless connection on the laptop to be shared with other computers on the network.
Sep 25, 2008 | HP Pavilion dv6000z Notebook
Connecting to xbox live
I can make it work for you
Feb 11, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
