CENTRAL AIR My central air conditioner blower won't turn off and the A/C won't turn on, can anyone help me with this please?????
    Problem Solver:
  • 10 Answers
Many low voltage circuits "flag" you when there is a problem by running the fan when the low voltage circuit is broken by a blown fuse, open high temperature safety or a similar interruption in power. A qualified service technician can tell what the cause for power interruption is and correct the fault that caused the problem to occur. There may be a short in the wiring or overheating in some part of the system. A dirty air filter while running the heat cycle can trip the high temperature safety - but so can a faulty burner flame. Be safe and have it looked at.
Posted on May 03, 2008
Central heating&cooling
sounds like your compressor is getting hot and shutting down have you washed your outside condenser coil? Could be dirty causeing high head pressure and shuts your compressor down. Try washing your condenser coil I think this will help you. If not you may be low on charge of Freon.
Aug 17, 2014 | Rheem 13AJN30A01 Central Air Conditioner
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Central air not working
the pilot light has nothing to do with the operation of the central 'air' system.
As to the central 'heat' system however, it must be lit.
hope this helps.
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Air conditioner blower fan wont turn off
If this is central AC unit check the fan motor to see if it will try to run. If the motor tries to run it may be capacitor easy to change. If not posible fan relay. Please keep in touch and I will help you with this problem. Rus Need more info please.
Nov 11, 2009 | Heating & Cooling
Turned on a/c unit no air blowing from vents. unit is on out side runing
2 things could be the problem 1 The blower motor capacitor has one out. This is a small oval or round piece that the wiring to the blower motor is attached if this is out the blower motor will not work. 2nd. the blower motor itself has burnt out. Replace the capacitor and the motor together should you have to change out the motor. Good luck hope this helps
Dave
Sep 04, 2009 | Ruud Central System Air Conditioner
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Central air conditioner will not turn on at all.
I understand this to be a heat pump. Check your thermostat settings, and the filters. And make sure a breaker isn't tripped.
May 21, 2009 | Carrier Heating & Cooling
Central air
First turn your thermostat to the fan on selection, if this allows the blower to run then replace the stat. If blower will not run in on selection it is either a bad control board or blower motor. I can walk you through getting the blower on if the board is bad so it will operate until you replace it. Thx RepairUSA
Aug 25, 2007 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
145 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
