I have jvc av-48wp30 48 in.my picture just started to have red lines in it and the picture looks like its dobbeling up
  • Richard Lowen Apr 13, 2009
    NO PITCHER BUT RED LINES ACROSS THE SCREEN
  • 2,326 Answers
You will need to change the convergence assembly. Here is the entire assembly from partstore.com or you can just replace the 2 big black ICs that are mounted on the aluminum heatsinks and may be a couple of the resistors that might be open.
Posted on Apr 28, 2008
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Red lines are taking over
possible your tripler control is going out .This part splits the high voltage from flyback transformer into 3 high voltage leads to feed to the three picture tubes .The side for the red is likely to go out causing red picture tube to overdrive in red retrace lines..That or RED CRT BOARD is bad
Dec 06, 2007 | JVC AV-48WP74 48" Rear Projection...
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
My JVC wont converge the red lines so half my screen is good while the other has red lines. What should I do? Thanks A lot
The tv 100% have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors picture shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | JVC AV-48WP30 48" Rear Projection...
My tv is a jvc av-56wp74 it looks like 3Dwithout the glasses the colors dont line up
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | JVC AV-56WP74 56" Rear Projection...
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Double picture
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 31, 2008 | JVC AV-48WP74 48" Rear Projection...
Red bending lines shadowing all other correct parts of the picture
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Aug 03, 2008 | JVC AV-48WP74 48" Rear Projection...
Red is all over the place but have a claer picture.
Its a convergence problem. I had the same problem you have to replace an av 110 chip in the tv.Mine was under warrenty so I had it fixed for free. Dont know what it costs otherwise.
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
