Question about Alpine CDA-9885 CD Player
CDs and Ipod wont play with Alpine CDA-9885
I got my new Alpine head unit and i cant see to get my Cds or ipod to play through it. When i put in Cds i only hear my subs goin. Is there somthing i am doing wrong? Radio works fine
    Scholar:
  • 82 Answers
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Posted on Apr 17, 2009
Cda-150 alpine head unit
try pressing the source button to select ipod
Feb 07, 2010 | Alpine CDA-9885 CD Player
No subwoofer with Ipod or CD but works with Radio - CDA-9885
You need to switch from the blue to the blue/white on harness...you are using the antenna turn on...which powers down when in aux mode or cd mode...
Jun 11, 2009 | Alpine CDA-9885 CD Player
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
How do you hook an ipod up to the CDA-9885 Alpine sterio?
Hello billybob3491,
The best way would be to add the Alpine optional proprietary iPod connection cable. This will give you full control of the iPod from the radio. Your CDA-9885 uses the KCE-422i optional cable.
The cheapest way (with lower quality audio) would be to use a generic FM modulator with a mini-jack input. The Scosche FMMOD01 shown here is sold in numerous stores from $17 - $50. Another downside with this method is that you have no control of the iPod from your head unit. But, hey! It works.
Hope this helps.
May 04, 2009 | Alpine CDA-9885 CD Player
Cda-9885 ipod not searching
I had the same problem. I got it resolved by making the MIX OFF. Just press the button number 5 to make the MIX (Random Play)ON/OFF. After the search you can set the MIX to ON. However set the MIX to off before you start any search every time.
Jan 18, 2009 | Alpine CDA-9885 CD Player
Alpine CDA-9886 error 1
Try turning off the password lock or password if you have one. That fixed mine. I had an identical problem.
Jan 10, 2009 | Alpine CDA-9885 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
Cda 9883 and cda 9885 2008 model no song issues
My ipods fuction fine with my Alpine CDA-9885 ... have you tried pressing the display button on the Alpine? The KCE-422i cable takes quite a beating ... You might check the cables.
Feb 14, 2008 | Alpine CDA-9883 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
Alpine CDA-9885 CD Player Logo
482 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
