Question about Zenith P42W24B 42 in. Plasma Television
Dead power lite on,green ,,rf board 4red lites on?????
  • 2,323 Answers
If you are able to hear audio but no video, your Ysus assembly might be defective. It could also be your power supply not providing all the voltages to the different assemblies on your TV.
Posted on Apr 28, 2008
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Hi Don
first thing to check would be all power leads and fuse to clear those areas from the list. Providing all of these are correct, it looks like either your power button has gone faulty of the power supply itself. I am not familiar with this particular machine, is it a normal tower sized machine? if so then a psu replacement is relatively cheap and easy, just make sure that the replacement has all of the connections that you require.
Philips 47PFL5603D LCD TV ,will not turn on,it did have flashing red lite,insted of green,then it got a clear flashing lite,now there isn't any lite on,I have unpluged it,when you plug it back in,you...
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
May 13, 2011 | Philips 47PFL5603D 47 in. LCD HDTV
No power, tried a new power cord, still no power
Ur tv have any power lite flashes on the front power LED lite on the screen pannel?Yes,than the power supply board have dead leakage parts capaacitors,they bulges up on it top or puff off on it tops.U know basic electronic,soldering equipments and know soldering?Replaced those dead leakages gas capacitors on the power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | LG 50PG20 50 in. Plasma HDTV
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
Will not boot... black screen?
Try removing the battery completely and powering it up on AC power. Sometimes a dead battery (even if you're plugged in to AC) will stall a boot-up in its tracks. If this doesn't help, please reply back and let me know if anything changed.
Jul 09, 2009 | IBM ThinkPad T40 2373 Notebook
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
Zenith P42W24B 42 in. Plasma Television Logo
108 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
