Question about Dryers
Can't get the dryer belt on my maytag to go back on. It's as if it is too small.
2 Suggested Answers
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
Aug 31, 2011 | Maytag Dryers
How do I change the dryer belt?
Please check the bellow links to get the instructions as to how to change belts:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Feb 02, 2011 | Maytag Dryers
I placed a small load of clothes in the dryer turned it on and came back to the dryer 5 minutes later and smelled like somthing was burning. I don't believe the dryer ever started. I unplugged the cord...
Normally what happens in this case is the dryer belt snaps. You can test this by turning the dryer on without any clothes in it. If the drums heats up but does not turn/rotate the first thing to check is your belt. You could check the belt yourself if you have the knowhow or the expertise or you could get someone to have a look for you.
Dec 30, 2010 | Maytag Dryers
Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Jul 24, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
What is small blue plastic wheel?
The small blue wheel, just next to the Motor, is the tension pulley, your belt should go around it, before going around Drum
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making noise and quits running
You may need to replace the drum rollers and front drum glides. The motor definitely is bad and should be replaced.
A Maytag dryer is worth investing the repair cost.
Nov 12, 2009 | Maytag Dryers
I have a maytag dryer DG712 that needs the belt replaced
Should be able to take the back off. should see several screws holding the back on, The removable back is usually a metallic color and not the same color as the cabinet If not, while looking at the back notice where the top and back meet in the seam there should be a metallic looking clip or hinge with a screw in it. Lossen screw dont take it all the way out then go to the front of the dryer and where the seam is between the top and cabinet take a flashlight and look for the two clips are in the seam take a flat tip screw driver and push in on both of these and without marking up the dryer lift with screwdriver against the top. Top should open up then you should be able to get to the belt easier.
Aug 25, 2009 | Dryers
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Jul 03, 2008 | Maytag Dryers
Dryers Logo
Top Dryers Experts
