Question about Apex Digital AD-1110W DVD Player
Tv screen rolling vertically when trying to use my DVD player
My TV works fine, but when I try to play a DVD, the tv screen
rolls.
Thank you.
Diane
    Genius:
  • 3,587 Answers
That's a synch issue..is the cable tightly installed? do you need to have that on another channel, by chance?
Posted on Apr 28, 2008
Yeah I have a Sylvania model # SP A2751 106. It is a old **** tube tv. When I go to hook up the the dvd player and switch it to vcr/aux the picture rolls in bars upwards. Its not the dvd player tried it on...
There should be a preset resistor on circuit board of old CRT based TVs, designated as vertical rolling adjust. Try to locate it and adjust a little till rolling stops, while playing the DVD. The set will be live during this process, so be careful. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 25, 2013 | Televison & Video
Dvd player causes the tv screen to roll when trying to play a dvd. tv works finf when the player is off
Have you ensured that the dvd player settings are set to pal and that if the disc in use is an ntsc disc that the dvd is set to ouput pal60 or pseudo pal
Dec 29, 2009 | Insignia Televison & Video
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Vertical Hold Problem when connecting DVD Player
they have different resulutions they can synk
Nov 18, 2007 | JVC AV-32432 32" TV
Hooking up dvd player
Your cables are coded red(right audio), white(left audio) and yellow(video). The cable inputs on the dvd player and tv are likewise coded. Just connect color to like color. In setup, do not
change NTSC! If you should go to PAL you'll never get out of setup and all you'll have is screen roll, as though the vertical hold gave out.
Sep 18, 2007 | GPX D1816 DVD Player
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Apex Digital AD-1110W DVD Player Logo
284 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
