Question about Brother Office Equipment & Supplies
Drum light on Ready light on Alarm light on Data light on
  • pastorcosby Jul 02, 2008
    my Alarm and Data light is on and can not print
  • Anonymous Nov 24, 2008
    Alarm and Data lights on. I pulled cartridge and thoroughly examined the entire printer. No paper is in the cartridge or jammed. Cannot print. Help
Alarm and Data lights on together is from low toner. If shaking of the toner cartridge is not helping, change the toner.
Drum light is usually on because of the print counter. If the print quality goes really bad, change the drum and reset the counter by holding the front button wile the front cover is open till all lights come on. Release the button and close the cover.
If just Data light is on, check the print ques, some jobs might got stuck there.
Posted on Dec 14, 2008
Drum, alarm, and data lights on--won't prnt
This unit might need resetting!
Here's how..
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Aug 01, 2010 | Brother HL 1440 Laser Printer
My drum light and the ready alarm and data lights are all flashing and I just put a new drum in and the lights are still flashing and it is not printing.
Follow the link below to see what the light flashing mean.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000070/faq000170_012.html?reg=us&c=ca&lang=en&prod=hl1440_all
Apr 05, 2010 | Brother HL 1440 Laser Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Drum light, alarm light and data light stays on. Does this indicate that the drum and toner need to be replaced?
Yes, drum light means drum is nearly used up, and alarm plus data means the toner is almost gone.
Jun 19, 2009 | Brother HL 1440 Laser Printer
All lights are flashing not printing
Might have a paper jam in area of toner and drum cartridge that may need to be removed. Typically this will solve the issue.
Feb 11, 2009 | Brother HL 1430 Laser Printer
Drum, ready, alarm, and data light all flashing
have you tried reinstalling the printer or driver?
Jan 04, 2009 | Brother HL 1440 Laser Printer
Printer Problems
Hi, it sounds like you need to change the drum. If you are using the High Yield TN660 toner is your printer, then the drum needs changing every 3-4 toners. If using the low yield TN6300 toner then your drum needs to be replaced every 6-7 toners. Hope this helps
Nov 20, 2008 | Brother HL 1440 Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
649 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
