Question about Lexmark T642 Laser Printer
Printer stops working until reboot
I'm using a Lexmark T642 with Windows XP Pro over a USB connection and I have the following issue: After leaving the computer and the printer powered up overnight, the printer will (seemingly randomly) not respond to any printer commands. I get no error messages, the printer simply does not print. The only way I've been able to solve this problem is to reboot the PC. Has anyone had this problem that can offer some advice?
Thanks
  • Joseph Allan Jun 02, 2008
    I have the same problem with a T642 Lexmark setup on a network. There are four T642 Lexmarks but only one of them has so far had the problem. The printer stops working from the main Windows 2003 Server about once a month however printing directly to the printer from other computers seems to be fine. All Lexmarks use the same drivers.
    Separate issue that may be related;- The drivers were originally installed from versions downloaded off the Lexmark Site. The printers on the server were not setup as shared printers however it was subsequently found if the printers were shared a problem would occur on any computer trying to connect to them, specifically on a Windows 2000 computer "LMAAT2PI.exe has generated errors and will be closed by Windows. You will need to restart the program." The drivers also caused havoc in the Citrix environment. I have just recently run the CD install utility on all environments by installing one Lexmark T642 printer shared and the sharing problem has been fixed for all Lexmarks on the server. I now have to wait a month or two to see if this also fixes the reboot required issue.
  • 3 Answers
Could you provide an example of the commands you used?
Posted on May 15, 2008
I have Lexmark Prestige 805 It seems like I keep losing my printer connection, I have to turn the power off the printer and back on again to make it work or re-download the print driver. I used to have...
Please follow the steps below to fix the problem you are experiencing:
First, uninstall your existing printer driver from your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark folder.
  4. Pro800 Series folder.
  5. Uninstall Lexmark Pro800 Series.
After the uninstall process, reboot your pc when prompted. When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type if it's a 32-bit or 64-bit.
Second, use the link below to download and install the Lexmark Prestige Pro805 driver for Windows 7 from the Lexmark website. Use the correct driver for your operating system.
- Lexmark Prestige Pro805 Printer Driver for Windows 7 32-bit
- Lexmark Prestige Pro805 Printer Driver for Windows 7 64-bit
Follow the instructions on your computer screen to re-install the printer driver.
Sep 01, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
I need instructions on how to install my lexmark office all in one with fax x4270. i used the cdrom and I have a usb port
install the cd first. and do not connect the usb wire first and follow the instructions.and connect the usb wire when it prompts u to connect the usb wire.
Oct 07, 2008 | Lexmark Office Equipment & Supplies
Nvram mismatched for t642 lexmark printer
The NVRAM settings on the T642 could have been corrupted. You can try to restore the factory defaults by following the instructions in this article http://bit.ly/dn3wIC If that does not fix the problem you are probably looking at replacing maybe the System Board.
Feb 19, 2010 | Lexmark T642 Laser Printer
T642 getting a watchdog error with no other error codes
Hi, the way to fix this problem is by updating the firmware on your printer. Go to support.lexmark.com/printerfirmware and use the following keycode: lsstp240 that will download the firmware that you need to flash to your printer. To flashed you can do the following. If your printer is connected to the network then go to a browser and where you will type the Url (ex www.fixya.com) type the IP address of the printer. Then go to configuration, then go to Update firmware and browse for the firmware that you just downloaded and hit send. The printer will start beeping and saying updating firmware do not turn off. Once the firmware update is complete then the printer will restart and you should not see the watchdog error again.
Dec 30, 2009 | Lexmark T642 Laser Printer
I have bought a new Lexmark x5650 Printer. The setup all went fine but everytime i boot my PC running Windows XP the screen just hangs. When you take the USB cable out of the Printer the PC carries on...
Issue: Computer will not boot with the device connected via USB to the PC
Solution: Disable USB Emulation (legacy support) in the computer BIOS
Turning off USB Emulation (legacy support) in the computer's BIOS
The following steps are for Dell computers. If this issue is occurring on another brand computer, the process of entering the computer's BIOS may be different. Additionally, the steps to make changes may differ as well. Refer to the computer's documentation to verify the appropriate steps to disable USB Emulation.
For Dell computers, perform the following steps:
While rebooting the computer, press the <F2> key to enter the System Setup (BIOS).
Press the Down Arrow <?!> key repeatedly until 'Integrated Devices' is highlighted.
Press <Enter> and another window appears.
Press the Down Arrow <?!> key repeatedly until 'USB Emulation' is highlighted.
Press the Plus <+> key to change the value to 'OFF'.
Press the <Esc> key to exit this window.
Press the <Esc> key again to exit the System Setup (BIOS).
When the message "Do You Want to Save Changes And Exit" appears, press the <Enter> key indicating Yes to save changes. The system will reboot.
Jul 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
ERROR 1208 LEXMARK 4270 LOST MY MAN. WHAT DOES THIS MEAN. WILL NOT PRINT HELP!!!!!!
Important News Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannot connect my printer to my computer
This came right off of the lexmart site
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' -----> 'From scanner or camera' (while the Lexmark is in scan mode). Just tried it and it really works.
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark T642 Laser Printer Logo
830 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
